Old 03-16-2012, 12:47 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by Blown_xa View Post
Yes I do... Have a good assortment of pullers, and a couple of cheap ones which you don't mind modifying. Fifth gear itself has a lip for the puller, but most arms are too thick to fit under the lip. I had to flatten the arm points. And use a puller which has a cross bar ( keeps arms from spreading).
I'm actually past this point, and on the verge of reassembling it. I may have to replace a few gears that were damaged, and will definitely replace the bearings/seals, but the synchros all seem to be in good shape. As far as checking the bearing preload, I have access to a few different precision torque wrenches/watches, so that should only be a minor pain to set.
Oh, when I was pulling apart the bell housing and gearbox, I dinged the inside of the outer bearing sleeves (where the bearing between 4th and 5th goes) on the shaft splines. I can probably polish it down with a mild abrasive disc on a die grinder, but I'm concerned that it could have disastrous results, i.e. a spun bearing. Are those bearings supposed to have enough clearance to be able to spin the outer race by hand when mounted in the gearbox?
Old 03-16-2012, 09:21 AM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
The new carrier bearing come with new outer races, so use those for sure. As far as clearancing, for the tC trans I use a analog style torque wrench to measure the drag. The drag on the diff with the casing halves bolted together should be about 12to 20 in lbs from what I remember. Toyota sells the different size shims.
Ptuning.com
Blown_xa is offline   Reply With Quote
Injen Hydroshield Install and Review Sabretooth DIY / Maintenance / Service 12 07-18-2011 03:55 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
AOE Tigertec Spring install review detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 05-25-2009 01:36 PM
