Drives: yaris sedan 2077 Join Date: Mar 2012
My aftermarket radio is not powering on after removing the fabric one. I've checked the fuse, (7.5 ACC) but is fine. My fabric radio was working before I cut the cables to install the new radio, Is this cars has a release button to activate the power?? Please help..............
![]() Thanks, |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
No release button per se
Your aftermarket HU should show signs of life once you feed to it at least - positive 12 v permanent (yellow) - negative 12 v permanent - usually black - acc (may be red, not sure) - 12 v (you should have power here when you insert the key in the keyhole and turn it to the position when your stock radio is on ) check the above (you may use some testing device to check whether the problem is power (any of the above not supplied to your HD) or the HU) and do not forget to turn ON your new HU Last edited by TOLMACH; 03-17-2012 at 12:09 AM. |
Why did you cut any wires at all ? The wire harness for our cars cost between $6 and $12.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#4 | |
here is a harness (female side.. your car is male side) with color codes for wires - you can use it to check whether you made connections right (12+ constant, ground and accessory) http://www.crutchfield.com/p_1207017...ml#details-tab |
| Tags |
| radio, radio fuse, toyota yaris 2007, yaris 2007, yaris radio |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| Question on 09 Yaris Radio harness | fresnoyaris | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 05-04-2009 07:35 AM |
| Help with 09 yaris sedan kenwood radio? | Fiosguy | Cosmetic Modifications (Exterior/Interior) | 13 | 11-10-2008 11:59 PM |
