Old 03-18-2012, 09:32 AM   #1
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
Speed vs rpms
i have a 07 yaris and im finding it confusing to know whats my limit for each gear and i caint find it anywhere. I dont want to redline it i just like to go fast every once and a while. i know 1st is about 19mph i think but 2nd gear doing 40? thats as far as i went and by the 07 models not having a tach really sucks. Does anyone know the maximum speed for each gear?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 03-18-2012, 10:27 AM   #2
RedRide
RedRide's Avatar
Red line would be the same for each gear.
Other than that, I not sure what you mean by "limit".
Suggested speed limits for each gear are usually just for the best gas mileage.
However, even those suggested speed limits depend on road and driving conditions.
Old 03-18-2012, 10:32 AM   #3
ijose 845
ijose 845's Avatar
yes but i dont know how fast i can go for each gear. When i said limit i mean how fast can i go in 1st 2nd 3rd 4th and 5th.
Example: 1st gear goes up to 25mph, 2nd gear up to 40mph.
Pretty much i want to know whats the max speed for each gear
Angry Bird Crew #1
Old 03-18-2012, 10:44 AM   #4
RedRide
RedRide's Avatar
If desired, each gear can go uo to redline.
Again, other than that, what do want to know?
I've been driving standards for over 47 years and when you shift any car depends on the driving conditions keepng in mind not to over or under rev the engine.
Old 03-18-2012, 10:55 AM   #5
ijose 845
ijose 845's Avatar
Yes i understand that but what im trying to find out is what is the maximum speed for each gear. I dont have a rpm gauge in my car so im tryinng to find out what is the maximum speed for each gear.
Angry Bird Crew #1
Old 03-18-2012, 10:37 AM   #6
Em_
Drives: 2007 Yaris
yeah not having a tach must really sucks i'd like to answer you question but i never went that high with my yaris maybe check the youtube videos
Em_ is offline   Reply With Quote
Old 03-18-2012, 10:42 AM   #7
ijose 845
ijose 845's Avatar
yeah it really does. and i dont really want to install a tach cause i like keeping everything real clean inside my car i dont want to drill holes in anything :/
And i deff dont want to beat on the yaris to find out it.
Angry Bird Crew #1
Old 03-18-2012, 11:11 AM   #8
RedRide
RedRide's Avatar
Yes, but, max speed for what?
Best economy?
Best power ?
Etc.........?
Old 03-18-2012, 11:18 AM   #9
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I made a spreadsheet for my gearbox modifications to find out the different top end speeds for each gear. I also included a graph that shows the RPM drop between gears--both from 6000 RPM (6500 is the rev limit) and from the RPM that will land on 4000 (the lower limit of the power band is around 4200). The stock gearbox is pretty terrible between 1-2 and 4-5. These charts show the approximate speed that you can shift, either before redline, or to land on the sweet spot. Note that in either case, it's impossible to land on 4k in second gear due to the rev limit.
The first few times you take it up to 6k RPM, it's going to feel like it might explode, but it's still within its "intended" operating range. The way the chart works is: the numbers along the 6000 RPM line are your safe-ish limit. The numbers along the 4000 RPM line are your target shift points to maximize acceleration in the next gear.
Stock gearing:
To help reduce the RPM drop between 1-2, I'm using the Celica/Yaris RS gears for 1st through 4th and final drive. To make 5th gear less useless, I'm using a Matrix/Vibe/Corolla 5th gear set.
My custom gearbox:
Old 03-18-2012, 08:15 PM   #10
ijose 845
ijose 845's Avatar
Stock gearing:
My custom gearbox:
Oh so tell me if im reading this right
1st - 31.5 mph
2nd - 58mph
3rd- 85!!???
4th - 115!!!!!
so 5 is pretty useless like you said?
If thats the case then WOW i have been babying the shiit out of my car!!
in seccond i shift at 35 and i think its going to explode. Its good to know it has more power.
Angry Bird Crew #1
Old 03-18-2012, 10:33 PM   #11
CrankyOldMan
1st - 31.5 mph
2nd - 58mph
3rd- 85!!???
4th - 115!!!!!
The bigger issue with 5th gear is that it's so close to 4th that there's not much point in using it, unless you want to get slightly lower RPMs on the freeway. You'll know if you push it too far: the speed limiter cuts the throttle (fuel?) and it feels like the tires hit ice. Depending on your tire size, inflation, etc, you may have a few mph +/- on those numbers. I normally wind it all the way up getting on the freeway, but keep to about a 3k shift landing otherwise.
Old 03-18-2012, 12:13 PM   #12
Sparcoboy
Drives: 2008 XP9 by Sparco
If you want to accelerate fast you should not go to the limit, you should be able to feel it when you drive. If I do a quick start at the stoplights, I don't even look at the tach, you hear and feel it.
Sparcoboy is offline   Reply With Quote
Old 03-18-2012, 08:37 PM   #13
403RS
#yyc
403RS's Avatar
Drives: BSP '07 RS 5dr LB
I know that the auto tops out at ~170km/h (at an elevation of 3442 ft) :p
403RS is offline   Reply With Quote
Old 03-19-2012, 10:32 AM   #14
menz
Drives: yairs blue 2007 automatic 1.3
i can tell u about automatic, when you shift it yourself by changing the lever.
1st: 60 kph (35mph)
2nd: 100kph (62mph)
3rd: 170 kph ( 105mph)
i know when i get to the redline by the weird vibrations that start happening so next time just push your car and wait for the vibrations. I heard it is because the ECU will start cutting the fuel off when you get to 6500 rpms.
My sister has an 2000 echo i remember i got these numbers on 1st 36mph and i think i got over 105 on 2nd never tried to top the 3rd or 4th.
menz is offline   Reply With Quote
Old 03-19-2012, 11:11 AM   #15
ijose 845
ijose 845's Avatar
These stats all work! thanks for the impput guys! I drove today and tested them out and now i feel the little PEP the yaris has :) now i can finally enjoy my car. Thanks guys! Now about that gearbox!!
Angry Bird Crew #1
Old 04-08-2012, 11:13 PM   #16
hellstang947
Drives: 2007 Toyota Yaris
The owner's manual says the max is 31 (1st to 2nd), 59 (2nd to 3rd), 86 (3rd to 4th). It says nothing about 5th.
hellstang947 is offline   Reply With Quote
Old 04-09-2012, 01:37 AM   #17
broody
Drives: Yaris 3dr 2009
Just gun it to find out.
broody is offline   Reply With Quote
Old 04-17-2012, 10:11 AM   #18
curtmaxwall
Drives: Toyota Yaris Spirit
Post
0-10 mph for 1st gear
10-20 mph for 2nd gear
20-30 mph for 3rd gear
30-40 mph for 4th gear
more than 40 mph for 5th gear
curtmaxwall is offline   Reply With Quote
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
LTA Land Speed Races Harvest Edition 2011 fnkngrv Off-topic / Other Cars / Everything else Discussions 10 01-12-2012 10:06 PM
I'm a worry-wort but I worry about RPM's DebbyM46227 General Yaris / Vitz Discussion 20 07-11-2010 07:22 PM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 05:31 PM
