![]() ![]() ![]() Drives: 07 Toyota Yaris Join Date: Feb 2012
Speed vs rpms
i have a 07 yaris and im finding it confusing to know whats my limit for each gear and i caint find it anywhere. I dont want to redline it i just like to go fast every once and a while. i know 1st is about 19mph i think but 2nd gear doing 40? thats as far as i went and by the 07 models not having a tach really sucks. Does anyone know the maximum speed for each gear?
Angry Bird Crew #1 ![]() ![]() |
Red line would be the same for each gear.
Other than that, I not sure what you mean by "limit". Suggested speed limits for each gear are usually just for the best gas mileage. However, even those suggested speed limits depend on road and driving conditions. |
yes but i dont know how fast i can go for each gear. When i said limit i mean how fast can i go in 1st 2nd 3rd 4th and 5th.
Example: 1st gear goes up to 25mph, 2nd gear up to 40mph. Pretty much i want to know whats the max speed for each gear
![]() ![]() Drives: 2007 Yaris Join Date: Jan 2012
yeah not having a tach must really sucks i'd like to answer you question but i never went that high with my yaris maybe check the youtube videos
yeah it really does. and i dont really want to install a tach cause i like keeping everything real clean inside my car i dont want to drill holes in anything :/
And i deff dont want to beat on the yaris to find out it.
#6 | |
Again, other than that, what do want to know? I've been driving standards for over 47 years and when you shift any car depends on the driving conditions keepng in mind not to over or under rev the engine. |
Yes i understand that but what im trying to find out is what is the maximum speed for each gear. I dont have a rpm gauge in my car so im tryinng to find out what is the maximum speed for each gear.
Yes, but, max speed for what?
Best economy? Best power ? Etc.........? |
2ZR swap. DO IT! Ask how!
I made a spreadsheet for my gearbox modifications to find out the different top end speeds for each gear. I also included a graph that shows the RPM drop between gears--both from 6000 RPM (6500 is the rev limit) and from the RPM that will land on 4000 (the lower limit of the power band is around 4200). The stock gearbox is pretty terrible between 1-2 and 4-5. These charts show the approximate speed that you can shift, either before redline, or to land on the sweet spot. Note that in either case, it's impossible to land on 4k in second gear due to the rev limit.
The first few times you take it up to 6k RPM, it's going to feel like it might explode, but it's still within its "intended" operating range. The way the chart works is: the numbers along the 6000 RPM line are your safe-ish limit. The numbers along the 4000 RPM line are your target shift points to maximize acceleration in the next gear. Stock gearing: ![]() To help reduce the RPM drop between 1-2, I'm using the Celica/Yaris RS gears for 1st through 4th and final drive. To make 5th gear less useless, I'm using a Matrix/Vibe/Corolla 5th gear set. My custom gearbox:
![]() ![]() Drives: 2008 XP9 by Sparco Join Date: Nov 2011
If you want to accelerate fast you should not go to the limit, you should be able to feel it when you drive. If I do a quick start at the stoplights, I don't even look at the tach, you hear and feel it.
#11 | |
Oh so tell me if im reading this right 1st - 31.5 mph 2nd - 58mph 3rd- 85!!??? 4th - 115!!!!! so 5 is pretty useless like you said? If thats the case then WOW i have been babying the shiit out of my car!! in seccond i shift at 35 and i think its going to explode. Its good to know it has more power.
#yyc
Drives: BSP '07 RS 5dr LB Join Date: Aug 2011
I know that the auto tops out at ~170km/h (at an elevation of 3442 ft) :p
#13 | |
![]() Drives: yairs blue 2007 automatic 1.3 Join Date: Apr 2007
i can tell u about automatic, when you shift it yourself by changing the lever.
1st: 60 kph (35mph) 2nd: 100kph (62mph) 3rd: 170 kph ( 105mph) i know when i get to the redline by the weird vibrations that start happening so next time just push your car and wait for the vibrations. I heard it is because the ECU will start cutting the fuel off when you get to 6500 rpms. My sister has an 2000 echo i remember i got these numbers on 1st 36mph and i think i got over 105 on 2nd never tried to top the 3rd or 4th. |
These stats all work! thanks for the impput guys! I drove today and tested them out and now i feel the little PEP the yaris has :) now i can finally enjoy my car. Thanks guys! Now about that gearbox!!
![]() Drives: 2007 Toyota Yaris Join Date: Mar 2012
The owner's manual says the max is 31 (1st to 2nd), 59 (2nd to 3rd), 86 (3rd to 4th). It says nothing about 5th.
![]() ![]() Drives: Yaris 3dr 2009 Join Date: Oct 2011
Just gun it to find out.
#18 | |
Drives: Toyota Yaris Spirit Join Date: Apr 2012
10-20 mph for 2nd gear 20-30 mph for 3rd gear 30-40 mph for 4th gear more than 40 mph for 5th gear |
| ABS and "!" lights are ON again! | onizuka | Canada | 457 | 04-28-2023 09:40 AM |
| LTA Land Speed Races Harvest Edition 2011 | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 10 | 01-12-2012 10:06 PM |
| I'm a worry-wort but I worry about RPM's | DebbyM46227 | General Yaris / Vitz Discussion | 20 | 07-11-2010 07:22 PM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
