Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-22-2012, 06:46 AM   #1
d"A"
d"A"'s Avatar
Drives: Yaris Y 2012
Going Down the Cliff
Hello po mga sir's. Ask lang ako ng question if you stay sa 2nd gear if palusong yung trail? As per my driving habit kasi with a company car before I go in neutral then alalay sa preno. Pero sa manuals ng mga sasakyan ang recomended nila is stay on 2nd gear para sa engine breaking. Ang sa akin lang is hindi ba masama sa engine yun lalo na kung mahaba-haba yung trail like yung way papuntang Jeddah from Riyadh sa Makkah High way?
d"A" is offline   Reply With Quote
Old 03-22-2012, 04:31 PM   #2
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
I stay on 5th gear at least hindi gaining violent ang engine braking at walang masira alalay pa run
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-24-2012, 12:57 AM   #3
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
@ d"A" depende sa steepness ng downhill drive mo at speed mo, as long as equal to or less than 3K ang rpm mo ( 4K rpm is still ok), safe pa un. ang drawback lang sa naka neutral when going downhill at alalay sa preno ay wala ka masyado control sa sasakyan. engine braking is advisable as per the manual and as per my experience as well. my yaris ( shadow) is going 60K+ still on original brake pads.. FTW!
syntax is offline   Reply With Quote
Old 03-24-2012, 09:43 AM   #4
Marlboro
Marlboro's Avatar
Drives: Yaris
wow 60k na orig brake pads pa din ???? ayos di ka mahilig mag preno ata pao hahahahaha kung walang trapik at pababa neutral na lang hahahaha parang roller coater ride hehehehe kidding aside tama si syntax wag lang over rev kasi kawawa ang makina ni moniko
Marlboro is offline   Reply With Quote
Old 03-25-2012, 01:02 AM   #5
syntax
syntax's Avatar
nyahahhaha hindi talaga pre' hehehehe, kapag traffic ay alalay lang ako at hindi ako nakatutok para no need para sa sudden apak ng preno,
Old 03-24-2012, 01:03 PM   #6
charlieXX
Corporate Slave
charlieXX's Avatar
Si Pao kasi yung preno niya stock is made of titanium with ceramic lining na brembo ang tatak he he he stock pa lang jun tol he he he
Old 03-25-2012, 01:03 AM   #7
syntax
syntax's Avatar
nyahahahahaha..
Old 03-25-2012, 06:31 AM   #8
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
waahhhh ung preno ko maingay nanaman...
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 03-25-2012, 08:06 AM   #9
syntax
syntax's Avatar
pssttt.... iba po yan sa OP wehehehehehhe peace po..
Old 03-25-2012, 01:05 PM   #10
duke_afterdeath
e usapang preno kc kau kaya ayan
Old 03-25-2012, 08:10 AM   #11
charlieXX
Corporate Slave
charlieXX's Avatar
Baka gutom, diba pagka gutom ka maingay sikmura mo ganun lang yun.....
Old 03-26-2012, 03:13 PM   #12
gwafu187
Drives: Yaris Y 2007, Blue
same here, especially pag approaching na sa traffic signal, ramdam ko parang may laban pag nag aapply ako ng brakes...required na ba na magpalit ako ng brake pads or need lang konting adjustment.
gwafu187 is offline   Reply With Quote
Old 03-27-2012, 12:41 AM   #13
charlieXX
Corporate Slave
charlieXX's Avatar
Tol papaanong laban ng brakes you mean from left to right? or feeling mo advanced na ang preno ng unahan kesa sa rear....maaring adjust muna yan tol to synch the 4 braking system lalo na sa likod na minsan delayed (mataas na ba handbrake mo pagka hinatak mo, ako nasa 2-3 clicks pa rin mababa pa matigas na ikaw?)
Ilang kms na tinakbo mo?
Ako personally malakas ako sa preno as I don't do engine braking mas ok na akong maupudan ng brake lining kesa sa engine brake na I feel there is some stress given to the tranny and engine that overtime could cause some unnecessary wear and tear on those 2 large parts well that is JUST ME....my own personal feeling and opinion kaya preno na lang much cheaper to replace.
Old 03-27-2012, 02:48 AM   #14
syntax
syntax's Avatar
hehehehe ok pre' yan ang opinion at hindi conclusion nyahahaha
Old 03-27-2012, 02:30 PM   #15
gwafu187
@charlie, nasa 61K na Kms ko..yung laban na napi feel ko are both from right side (front & rear) medyo parang matigas pag nag apply ako ng brakes and yes parang advance yung brake sa front right side.
sa handbrakes its almost 30-40 deg. upright inclination which i think is equivalent to 2-3 clicks at normal naman pag hinatak. kung adjustment lang its ok ero kung palitin na yung break pads kailangang mapondohan na
Old 03-27-2012, 04:59 PM   #16
charlieXX
Corporate Slave
charlieXX's Avatar
Tol have it checked na a gad kasi kung matigas baka yung piston niyan eh corroded or madumi na
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
HID Light Conversion Kits - $170 shipped! MobileHID Sponsors Classifieds Area 120 05-02-2007 09:04 PM
