Huh that part about the crud in the coolant tank...
When your head gasket goes oil gets in the coolant, sludging up the radiator. And quite possible the overflow tank. When buying a car with the engine COLD remove the radiator cap. If the coolant is low AND theres oily looking stuff in there...excellent chance for a blown head gasket. Not to say your radiator wasnt bad but any crack in the radiator even plastic I would have to think would leak quite a bit. And since you faithfully changed the coolant in my experience that makes for a pristine looking expansion tank and inside of the radiator. There there not to worry youre driving a Yaris now! But if you want to be paranoid (and who doesnt where their car is concerned) check the bottom of the hood every few months on the right side for red streaks of coolant indicating a bad water pump. Mine went at 26k miles. I believe its covered under the drivetrain warranty for 60k miles or five years.
#2 | |
![]() ![]() ![]() ![]() Drives: 2017 Yaris IA, Pulse Red, Auto Join Date: Jun 2010
![]() I have 13K on mine, but I still check. And you are right, I actually read the entire manual the first weekend I got my car and water pumps are good for 5 years/60K miles. |
#3 | |
![]() Ah you didnt answer right away! Maybe you need to do some refresher work! I am seriously impressed you read your owners manual right away. ![]() Either you are crazy or I should ask you out. ![]() Or both...
| Belt Tensioner for the Yaris | fmicle | DIY / Maintenance / Service | 25 | 11-26-2022 11:37 PM |
| Serpentine belt squeals on cold start up after replacement. | YarYarBinks | DIY / Maintenance / Service | 16 | 03-03-2017 10:04 AM |
| Serpentine belt replacement. | Phaeton | DIY / Maintenance / Service | 4 | 01-10-2016 07:58 AM |
| Need new Serpentine/Auxilliary belt | ras3448 | DIY / Maintenance / Service | 21 | 07-16-2013 05:11 PM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
