Bob
Drives: Yaris and Scion XD 5 spd BSP Join Date: Dec 2009
TPS problem...
Before you take it to a dealer, try this:
Near the throttle pedal, there is a connector with aprox 4 wires that is very close to the firewall. remove and re-insert the connector. When you get it apart, get some DAMPENED micro fiber cloth and wipe the pins that insert into the plug. I had the same problem and it was a loose connection/poor contact in the tps connector. Please do it quickly! Mine started with the dead-pedal scenario and one day went to full throttle without my doing anything. After cleaning and redoing the contacts, I have not had it reoccurr. you need to squese the connector lock in order to take the plugs apart. It's really simple but you need to squeese hard. I used a 4 1/2 inch channel lock plier to do it. http://www.amazon.com/Channellock-42.../dp/B00004SBCR |
| 3 Drive Throttle Contoller by NTD | Sabretooth | Performance Modifications | 31 | 10-07-2010 12:12 PM |
| Group Buy for NTD 3Drive throttle controller | twpanson | Sponsors Classifieds Area | 35 | 11-17-2009 10:18 PM |
| Blitz throttle controller | 808_Yaris | Performance Modifications | 43 | 10-22-2009 04:36 AM |
| Throttle position used as cruise control? HELP | Appalachian Trail 2007 | Performance Modifications | 11 | 11-09-2008 11:10 PM |
