Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-26-2012, 03:07 PM   #1
gwafu187
Drives: Yaris Y 2007, Blue
Not using A/C for 3 days now may napapansin akong kakaibang amoy (something like nasusunog na goma), pag naka-on ang A/C walang kakaibang amoy, i guess this kind of smell is coming from clutch lining? coz for some delay of releasing the clutch then merong konting sticky upon releasing the feet from the clutch pad, for changing the gear smooth naman siya at wala namang sabit, i guess some of you guys ay may idea sa ganitong problema. is it normal or need ko ng dalhin sa shop? input pls...
gwafu187 is offline   Reply With Quote
Old 03-27-2012, 12:36 AM   #2
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
First question: Are you a clutch driver? do you hang on to the clutch longer than usual or full release agad?
It could also be electrical wiring burning may aftermarket mods ka na ba? sound or lights?
Monitor mo muna tol ako dati may naamoy ding ganyan I just pushed in all the fuses and checked the connections under the dash nawala naman
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-27-2012, 03:56 AM   #3
gwafu187
Many thanks sa mga inputs po ninyo, @charlie im not hanging on longer than usual, as soon as changed into next gear, unti unti then release...good idea to check 1st other causes...baka nga may mga nakasabit lang...ty po sa mga info.
Old 03-27-2012, 01:52 AM   #4
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
pre did you checked under the car? baka may nadikit na plastic sa may exhaust muffler or sa mga tubo nun? kaya parang may naamoy ka na nasusunog na plastic or goma?
syntax is offline   Reply With Quote
Old 03-27-2012, 01:59 AM   #5
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
ganyan din nangyari sa akin, amoy nasusunog, dinala ko sa toyota, normal naman daw, buti at nasabi ata ni duke sa akin na tingnan sa ilalim, yun pala dumikit yung plastic sa exhaust...hehehe
Ciao !!!
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 03-27-2012, 02:12 PM   #6
gwafu187
Natumbok mo @syntax...right after ofis hour sinilip ko sa ilalim...bingo!! may naka dikit nga na piraso ng plastik sa pipe na malapit sa muffler, masyado ng dikit ang hirap kunin...dapat siguro painitin ang makina para lumambot...ito ang maganda sa thread madaling naso solve mga mumunting problema...whew!!! nakaligtas ako sa labor cost ng ALJ..guys, salamat sa mga inputs nyo....
Old 03-27-2012, 04:15 PM   #7
charlieXX
Corporate Slave
charlieXX's Avatar
Ayos tumatanggap naman si Syntax ng prof fee in the form of puto pao or shrimps
Old 03-28-2012, 01:07 AM   #8
syntax
syntax's Avatar
nyahahahahahha ung puto pao ok un, ung shrimps para kay duke un wahahahaha
Old 03-28-2012, 01:58 AM   #9
xtremist
xtremist's Avatar
hehehe, oo pre, ligtas ka, gaya nga ng nasabi ko, nangyari sa akin yan at pumunta pa ako ng Toyota only to find out may plastic lang sa ilalim, kahit painitin mo yan, d yan matatanggal, kusa nalang yan malulusaw after a few weeks, yung akin may plastic nanaman sa ilalim, pang 3 times na ito nangyayari sa akin, hinahayaan ko nalang, inaalis ko nalang yung kaya alisin, ung nakadikit, titigas nalang yun pero wala ng amoy pagkaraan ng ilang linggo or kung makapunta ka sa talyer, iangat ko tapos alisin mo
Ciao !!!
