Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 03-27-2012, 12:36 AM   #1
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
First question: Are you a clutch driver? do you hang on to the clutch longer than usual or full release agad?
It could also be electrical wiring burning may aftermarket mods ka na ba? sound or lights?
Monitor mo muna tol ako dati may naamoy ding ganyan I just pushed in all the fuses and checked the connections under the dash nawala naman
Originally Posted by gwafu187 View Post
Not using A/C for 3 days now may napapansin akong kakaibang amoy (something like nasusunog na goma), pag naka-on ang A/C walang kakaibang amoy, i guess this kind of smell is coming from clutch lining? coz for some delay of releasing the clutch then merong konting sticky upon releasing the feet from the clutch pad, for changing the gear smooth naman siya at wala namang sabit, i guess some of you guys ay may idea sa ganitong problema. is it normal or need ko ng dalhin sa shop? input pls...
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 03-27-2012, 03:56 AM   #2
gwafu187
Drives: Yaris Y 2007, Blue
Many thanks sa mga inputs po ninyo, @charlie im not hanging on longer than usual, as soon as changed into next gear, unti unti then release...good idea to check 1st other causes...baka nga may mga nakasabit lang...ty po sa mga info.
gwafu187 is offline   Reply With Quote
