Old 03-28-2012, 05:39 PM   #1
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
Thank you scott, is it easy to remove inner joint from the transmission. ;)
Do i need to replace both side or just side has leaking grease.
yaris4062007 is offline   Reply With Quote
Old 03-28-2012, 07:35 PM   #2
TOLMACH
Drives: soarer
technically if the failed rubber boot is the only problem and the cv joint is ok (no knocking sound while you turn left or right) you can try replacing the rubber boot only
