Old 03-31-2012, 08:21 PM   #1
heeroyuy01195
Post count means nothing.
P0103 is Mass or Volume Air Flow Circuit High Input. Unfortunately, because of the bridge arrangement within the sensor, a Circuit High Input and a Circuit Low Input will give the same results, so you can't tell whether the sensor is open or shorted.
If you look at page 91 of the "Engine Control" section of the service manual, it shows how to check for continuity between the ECM connector and the MAF connector. Doing so will verify if the issue is a wire issue or sensor issue.
The service manual can be downloaded from Micro Image:
http://www.microimageonline.com/foru...32-YARIS-FILES
With both the C20 and C26 connectors disconnected as per the manual, my multimeter read stayed fixed at 1 for every test point. (The multimeter stays at 1 while not connected to anything during resistance checks so I'm assuming that it did not read any resistance?)
With the C20 ECM connector CONNECTED and the C26 MAF connector DISCONNECTED I got these values:
Check for Short
15.22k ohm
Check for Open
75.3K ohm
The check for open seems crazy high compared to what was stated in the manual.
Old 03-31-2012, 08:35 PM   #2
Check for Short
15.22k ohm
Check for Open
75.3K ohm
With the connectors disconnected, you should be measuring from the ECM connector to the MAF connector for each signal wire. Is that what you were doing when your meter showed the open circuit indication?
Compilation of Yaris TSBs eTiMaGo DIY / Maintenance / Service 72 07-04-2024 10:36 AM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
transmission light confused General Yaris / Vitz Discussion 3 01-22-2011 07:02 AM
