Old 03-31-2012, 08:25 PM   #1
With all that water in the air box, you may simply have an evaporative cooler effect.
Old 03-31-2012, 10:26 PM   #2
angrygenerator
Drives: 08 Yaris
You might be right, it certainly makes sense that cooling because of evaporation might occur..
Tonight I fitted a cabin filter and removed some paper that had gotten sucked into the unit. I also pushed a stiff wire up the outlet hose of the A/C, which caused about about cup of water to drain out of the pipe. Hopefully I've fixed the problem, but if not I guess I'll just have to take it to the dealer on Monday, and hope that Toyota agrees to fix what ever problem they find out, under warranty.
angrygenerator is offline   Reply With Quote
