Old 04-01-2012, 10:24 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Isnt the echos engine and drivetrain identical?
Originally Posted by Em_ View Post
yes it is i don't get the other statement
no it is not. The engine is the same.
they are closer than I thought though.
I wonder if the final drives will swap easy enough to change it.
The echo used the C150 gearbox, with ratios of
3.555/1.904/1.310/0.969/.815 reverse:3.250final=4.05
The Yaris is the C50:
3.545/1.904/1.310/0.969/.815/Final Drive: 3.722
Reverse: 3.250
as anyone who plays GT can tell you, the final drive makes a gigantic difference. In this case, it is the complete difference between the Echo's 99hp rating and the Yaris' 105. That and the extra 100+ lbs the Yaris has over the Echo tells why the Yaris won't get the same gas mileage.
sources:
http://www.cleanmpg.com/forums/showthread.php?t=252
https://www.google.com/search?q=toyo...ient=firefox-a
http://www.vibratesoftware.com/html_...sions.htm#C150
http://www.vibratesoftware.com/html_...oyota_Echo.htm
https://www.google.com/search?q=toyo...iw=911&bih=383
Colin Chapman disciple
Old 04-02-2012, 08:24 PM   #2
bronsin
bronsin's Avatar
Thanks for that I didnt know.
So which final drive gives you better mpg the 3 point something or the 4 point something?
I guess the auto tranmissions are the same?
Reverse: 3.250
sources:
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
