Old 04-05-2012, 09:02 AM   #1
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
belt was tightened 2 months ago when I had to replace water pump. bearings were out and making some hellacious noise.
If the voltage regulator is bad can that be replaced by itself? Or does it require a whole new alternator? I'll check the battery this afternoon when I get back from work like you said. Time to break that new multimeter out of the box ;-)
wsladaritz is offline   Reply With Quote
Old 04-05-2012, 09:26 AM   #2
The regulator can be replaced separately. There is a thread on here where I show the disassembly process and the part number for the regulator.
Trouble Code P2121 1nz DIY / Maintenance / Service 9 09-02-2024 07:59 AM
Alternator Trouble butter DIY / Maintenance / Service 1 08-10-2010 03:39 PM
Trying to find a H/O alt Slick In Car Entertainment + Electronics (audio / video / alarm) 11 09-16-2009 03:24 PM
Trouble Sleeping.... kac Off-topic / Other Cars / Everything else Discussions 27 08-23-2009 12:34 PM
Found a HO alt company plushDJ In Car Entertainment + Electronics (audio / video / alarm) 11 09-06-2007 06:06 PM
