Old 04-08-2012, 02:50 PM   #1
DARKSCOPE001
Drives: 2011 Yaris sedan
Originally Posted by vincentg View Post
so perhaps a tune up would be necessary?
as 09sedan said plugs cured his problem so it might very slight probable might. cure your problem. But a "tune up" as im sure your aware at many places means nothing more than new plugs. I encourage you to try doing them yourself. I havent tried doing any of these new coil on plug type ignition systems. But plugs are the the easyest thing to do on a car.
The good part is that if you become confident at pulling the plugs, They serve as a "window" as to whats happening inside the combustion chamber. http://www.aa1car.com/library/reading_spark_plugs.jpg But I really dont think that at 33kms anything should be happening like that. the car is still under waranty for gods sake
If it starts acting up take it in for a warranty repair at the dealership. Be firm with them and tell them what it is your expecting. dont let these "mechanics" walk all over you, nothing pisses me off more than being talked down to, especially at a car shop or watching someone else get talked down to, I actually had a Firestone mechanic talk down at me one time WHILE I WAS WEARING MY REPUBLIC AIRWAYS MECHANIC UNIFORM! it was quite insulting.
Best Luck
Sean Scott
DARKSCOPE001 is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Burning Smell peakthruclouds DIY / Maintenance / Service 5 01-17-2012 02:39 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
gasoline smell while driving? buffalogirl General Yaris / Vitz Discussion 18 03-24-2010 08:30 PM
Coolant Smell after sitting in hot sun? Snappy General Yaris / Vitz Discussion 3 05-31-2009 12:18 AM
