Derick you did away with 6x9s correct ? I don't believe Sq uses them either. And I don't use any either. Save the money you're gonna waste on 6x9s and get a 2 channel or 4 channel amp to push a good component set up front. Do the Big 3 and your electrical system will be fine. Its pretty safe to run 600 -800 watts RMS without having to upgrade your alt. If anything else shop for a battery.
Xs power , kinetik, stinger, etc. I would get that before speakers.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
http://www.sonicelectronix.com/pictu...ture_id=141929
Found this 4 channel locally for 120$.. Can i run off the factory wiring for the fronts? |
Yes,
At first I took them out the let the BASS go through from the trunk to the cabin, but now since I don't have my woofer in the trunk I sealed the openings with a double layer of MLV and CCFoam, to stop the rumble that it's generated in the trunk at highway speeds. Yeah I agree a big 3 helps, and it's less than $40 DIY D. .
. CLA 250, 4MATIC |
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| Why people choose a 5dr Liftback instead of a Sedan?? | SimmZ | General Yaris / Vitz Discussion | 53 | 05-29-2007 10:28 PM |
