Old 04-16-2012, 03:58 AM   #1
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
1) Yes, you should depress the clutch.
2) Coasting while in gear (not in neutral) will save you more gas. Check out this thread: http://www.yarisworld.com/forums/showthread.php?t=4248
The blue one
Old 04-16-2012, 10:16 AM   #2
djct_watt
Drives: 2010 NCP91 5spd
Honestly, this answer was the BEST answer and should be the end of the thread.
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 04-16-2012, 10:36 AM   #3
bronsin
bronsin's Avatar
Do you always do what Mama says?
Old 04-16-2012, 10:44 AM   #4
"But Mama, that's where the fun is"
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Shifting without the clutch mark293 General Yaris / Vitz Discussion 91 07-12-2010 08:56 PM
Shifting into neutral otterhere Fuel Economy Forum 24 01-17-2009 02:46 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
