Old 04-17-2012, 12:15 PM   #1
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
No idea how anyone got the idea of clutchless shifting out of the ops post. It is something that should never be done outside of a semi.
Originally Posted by djct_watt View Post
Honestly, this answer was the BEST answer and should be the end of the thread.
not it wasn't, it was wrong. Neutral will get better gas mileage in most situations, leaving the car in gear can get better gas mileage in certain unusual situations, like going down a very steep hill, or when you want to stop anyways. Other than those two situations coasting in neutral will get better gas mileage.
Throwing out this question to all of you. Let's say I'm in a gear (3rd,4th,5th, etc.) and I decide to shift into neutral to save some gas and coast. As a habit, I always press the clutch before I shift into neutral. Do I need to press in the clutch or can I just shift it out of the gear straight into neutral?
might as well use the clutch. It saves a tiny bit of wear and doing it often enough might add up.
Colin Chapman disciple
Old 04-17-2012, 02:35 PM   #2
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Neutral does not get you better mileage going down a hill or just coasting....you still have to rev match to put into gear again...and that blimp of the throttle isn't saving you more gas then simply leaving it in gear and shifting higher w/o blimping the throttle.
3 of us were making our way back down lots of mountains this previous weekend....we gained more mpg being in gear then in neutral. Plus.....you're just wearing out your brakes being in neutral coasting down....
Old 04-17-2012, 04:01 PM   #3
Sparcoboy
Drives: 2008 XP9 by Sparco
No you're wrong, when your in neutral, or depressed clutch, the car has to idle the engine, using fuel. When left in gear, clutch engaged, the car will drive the engine so no fuel is needed to keep the engine above idle.
Sparcoboy is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Shifting without the clutch mark293 General Yaris / Vitz Discussion 91 07-12-2010 08:56 PM
Shifting into neutral otterhere Fuel Economy Forum 24 01-17-2009 02:46 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
