Old 04-17-2012, 04:01 PM   #1
Sparcoboy
Drives: 2008 XP9 by Sparco
not it wasn't, it was wrong. Neutral will get better gas mileage in most situations, leaving the car in gear can get better gas mileage in certain unusual situations, like going down a very steep hill, or when you want to stop anyways. Other than those two situations coasting in neutral will get better gas mileage.
No you're wrong, when your in neutral, or depressed clutch, the car has to idle the engine, using fuel. When left in gear, clutch engaged, the car will drive the engine so no fuel is needed to keep the engine above idle.
Sparcoboy is offline   Reply With Quote
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Shifting without the clutch mark293 General Yaris / Vitz Discussion 91 07-12-2010 08:56 PM
Shifting into neutral otterhere Fuel Economy Forum 24 01-17-2009 02:46 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
