Old 04-30-2012, 02:14 AM   #1
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Originally Posted by packetrace View Post
BTW I will be in Boston for the whole week
So what's up in Boston? I think I'll be there on Tuesday or Wednesday, you should take the IDQ with you.
D.
CLA 250, 4MATIC
Old 04-30-2012, 12:34 PM   #2
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
I'll be there with school...so i need to follow the bus...I'll arrive on thursday 4AM...until sunday-sathurday....:(
And even if it would have been possible to see each other...I would have to take the sub with me all sathurday long...:(
Interior:ALL red, black roof
Old 05-01-2012, 12:29 AM   #3
derickveliz2
Ok, showing off the car to a complete Bus it's not a good idea.
But let me know if some thing works for you.
D.
CLA 250, 4MATIC
Old 05-01-2012, 12:32 AM   #4
packetrace
packetrace's Avatar
I have printed the manual today...I will read it in the bus while we are going to Boston :D
Thank you Derick!!
I am out until sunday!!
Have a nice week guys!!
BTW I have molded the trunk for fiberglass...Ill give it more layers next week :)
Old 05-03-2012, 10:16 PM   #5
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
why the polyfill stuffing behind the deck? Seems like that would increase the temperature of the deck, and any other electronics in that area.... Electronics don't like heat. I've got a denon deck with no internal amp that only has a 2amp fuse and it still gets hot when i play cd's.
I doubt the stuff does any amount of sound deadening if tha'ts what you are going for.
Old 05-03-2012, 10:20 PM   #6
derickveliz2
Exclamation
Agree!
See that black heat radiator (heat sink) in the back of the HU, I bet is looking for fresh air.
D.
CLA 250, 4MATIC
Old 05-06-2012, 04:01 PM   #7
packetrace
packetrace's Avatar
I had put it to see if it does make a difference because I had already seen it on Derick's thread...
I think it changes nothing...
Old 05-06-2012, 11:41 PM   #8
derickveliz2
I didn't use any polyfill over there, I did put a layer of CCFoam (for vibrations) and a heat barrier above the HU under the air ducts and above the air ducts. In summer the sun heats the dashboard pretty hard, also on top added a few peaces of foam to get rid of a rattle under the speedo cluster.
Radiant Heat Barrier:
D.
CLA 250, 4MATIC
Old 05-06-2012, 09:43 PM   #9
packetrace
packetrace's Avatar
I started tonight the deadending progress...
Do I put enough ?
Old 05-06-2012, 11:45 PM   #10
derickveliz2
Thumbs up
Do I put enough ?
Yeah that's more than enough, but what really is going to make a difference since you will have a sub i the trunk is to cover with a layer of MLV all the floor, wheel wells and side panels, other wise you will end up with a HUMMM from the trunk.
D.
CLA 250, 4MATIC
Old 05-06-2012, 11:49 PM   #11
derickveliz2
And leave at least one drainage just in case!
And don't forget to make a chamber for the air vent, that is where most of the direct road noise gets into the cabin, you can do the following test now that your trunk is naked, lower your rear seats and drive on the high way, listen carefully while switching back and forth the air from circ to outside, you will hear the chamber open and close.
D.
CLA 250, 4MATIC
Old 05-07-2012, 10:15 AM   #12
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Watch out! The fuel tank calls in that area...
― Thomas Paine
Old 05-07-2012, 04:09 PM   #13
packetrace
packetrace's Avatar
I have left a drainage :D
I'll check it for the air vent...
And...I have tried to get the back seat out....what a pain!!!!
I have stopped before I commit suicide!
Old 05-07-2012, 11:37 PM   #14
derickveliz2
I remember that, I hit the roof with my head so hard (and loud) that I had to go up stairs and check the kids. LOL
It's a pain for sure.
D.
CLA 250, 4MATIC
Old 05-07-2012, 08:56 PM   #15
packetrace
packetrace's Avatar
This afternoon I fired up the amplifier!!!
Wow!!! It makes a huge difference already!
For now I have only the Mids..which are actually the Pionner premier 6.5''..
Tomorrow I will wire and fire the L1v2! I will just drill a big hole in the a-pillar for now..Somewhen I will do like Derick did...put the tweeter in a plastic bag and put bondo under it to fit the tweeter on the a-pillar...
I can't wait to hear the L1v2 running!!
I haven't choosen a subwoofer for now...I am tempted by the Alpine type-r...
Old 05-07-2012, 11:14 PM   #16
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
alpine subs are totally insane. Make sure you want crazy SPL, because Alpine dishes it all up. Honestly I think Type R might knock you unconscious in a car as small as the Yaris.
Colin Chapman disciple
Old 05-09-2012, 12:18 PM   #17
packetrace
packetrace's Avatar
Here an update...
started to deadend some small parts...with MAT and Ensolite..
