Old 04-19-2012, 10:38 PM   #1
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
Older Toyotas often seized up their wiper pivots. The motor was generally ok it just could not overcome the stiffness of the pivot shafts. Not sure how it works on the Yaris with its wiper "assembly" but if the motor is removable it may behoove you to see if the rest of the assembly moves freely once removed. Possible lubrication might be the solution. If that is the problem a new motor won't work any better.
Tardis is offline   Reply With Quote
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
front wiper issue 2009BBPliftback General Yaris / Vitz Discussion 1 12-17-2009 08:16 AM
