Old 04-24-2012, 05:37 PM   #1
swiftyman
Drives: 2007 Yaris
I don't have side curtain airbags, but I just popped that off and its not open. There is just solid metal behind it :(
If I take the dash out is there any opening behind it? Or am I pretty much screwed?
swiftyman is offline   Reply With Quote
Old 04-24-2012, 05:58 PM   #2
I forgot about the fact that there are only little holes under there into that hollow tube. The only large access into it is where the wire protector is for the wiring from there to the door.
When you had the cover off did you sniff around to see if the smell was stronger and hence you are looking in the correct place?
I've NEVER been more curious to find out! Syroyizhka General Yaris / Vitz Discussion 5 04-15-2009 07:35 AM
Dead Pedal absenter Cosmetic Modifications (Exterior/Interior) 5 03-31-2007 05:47 PM
Pedal covers and dead pedals.. what is out there we can use? largeorangefont Cosmetic Modifications (Exterior/Interior) 8 01-15-2007 04:55 PM
