#1 | |
Do you see the point if they intend to push it to 250-300? Because that's what's up on this build.
Let's just leave it alone, guys and enjoy the hell out of pimp's build. Quote:
#2 | ||||
Only Happy When it Rains
1.The problem is every modern straight engine I've seen the experience ends up like Dent Guys: Quote:
Now the reason for this is this is the main difference between straight engines and V engines. V engines are V because the harmonic differences offset each other with the degree of the V. Which is why the angle is different between v4, v6, v8 , etc. Flat engines don't have any of that vibration, because they are in a row, all working the exact same way in the same directions. Which is also why the harmonic dampeners on our cars are basically nonexistent. 2. It simply isn't cheap. Anyone who says they can balance your engine for $250 has no idea what they are doing. There is a reason balancing and blueprinting go hand in hand, they are basically the same type of labor, Anyone who you would trust to do this isn't going to be cheap. It is going to be at least $1000, probably more, depending on how familiar the person is with the engine in question. Just think about it, the engine at the least has to be disassembled and reassembled. 3. Quote:
Just like I know engines in the top racing series are all balanced.blueprinted, etc. It would be dumb to not do it. Basically V engines and straight engines are two very different beasts when it comes to vibration. Here's the real thing though, I don't know anyone with a modern straight engine who's ever done it and the car needed it. Like Blown Xa said, it could be insurance money. so if you know a great engine builder and have the extra couple of grand on hand, you might as well go have it done. But as Dent Guy said, if you're on a budget there are many better things to put your money toward. Now come on, prove me wrong. Show me the results of all these straight engines and their extensive balancing reports.
Colin Chapman disciple |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
yea enough talk let see those parts; see the build; see the video; and listen to the purr, wine, and whistle of the turbo as the Yaris winds up.
This thread needs more photos to stare at :D
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
![]() ![]() Drives: Gen 1 XB Join Date: Nov 2012
Just a quick tip. Hoppe's gun cleaning solvent is a great tool for applying to your engine fasteners prior to trying to break them loose. Squirt some on each fastener, and it will help counter the effects of dissimilar metal corrosion (shank siezing) between the steel bolts and aluminum block, head, etc. Just make sure to allow it plenty of time to "wick" down into where it needs to go.
Why strive for a JDM BB, when you can promote the Scion badge? |
play every day
Oooh... Hoppes #9. The shooter's perfume.
