Old 04-30-2012, 08:41 PM   #1
Originally Posted by Blown_xa View Post
I wouldn't tag a certain amount of boost to the limitation of stock rods.... It is power. Most likely the onset of power (torque) is the best measurement of limitation.
True, although it is the instantaneous force of the combustion explosion pushing against the crank before the rotation occurs that does the damage, as that peak force can be in excess of 6000 lbs. That force is the pressure within the cylinder at combustion multiplied by the area of the piston and by the sine of the angle of the rod at TDC (which is about 10 degrees). So, if that force peaks high enough either the bearing or rod will fail.
Old 05-01-2012, 09:23 PM   #2
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yea, detonation will kill rods at any power... I meant considering a bad tune not being the culprit .
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 04-30-2012, 08:42 PM   #3
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
^^this
Yoda is offline   Reply With Quote
Old 04-30-2012, 09:04 PM   #4
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
CP 9.5:1 pistons, Pauter rods and a new clutchmasters fx300 clutch ordered today from Micro Image. And now Im broke.
pimp my yaris is offline   Reply With Quote
Old 04-30-2012, 10:32 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by pimp my yaris View Post
And now Im broke.
Broke, but that first time that you drive it with the upgraded internals you know that you will have a shit eating grin on your face
Old 05-01-2012, 12:53 AM   #6
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
wow your build progress just never ends does it,
i myself just pulled a stock zage kit and going just low boost but now you upgraded internals. your internal upgrading thread would be a very very educative as your kit installation build had been.
2 thumbs up for you...
Schizoprenia is offline   Reply With Quote
Old 04-30-2012, 10:46 PM   #7
ooh you went 9.5:1 -- NICE...
sorry about the broke part...
Old 04-30-2012, 10:47 PM   #8
I don't think CTScott was doubting you, I think he wanted to see the chart.
Old 05-01-2012, 02:00 AM   #9
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
I've always wondered this and could probably use to read about a bit but... How is the engine going to perform with lower compression on stock management?
Focus_Sh1ft is offline   Reply With Quote
Old 05-01-2012, 05:31 AM   #10
thefalls
Drives: Axio GT
Well lower compression will make a lazy engine off boost. I drive a very low compression engine 4efte with 7.8:1 compression[stock management and not tuned yet, at 0.5bar td05].A bit lazy offboost but when on boost it does fly :).
I would assume that 9.5:1 would be much better a drive.
thefalls is offline   Reply With Quote
Old 05-01-2012, 07:44 AM   #11
pimp my yaris
C'est la vie
I was going to stick with stock compression ratio on the advise from my friend who is helping me with the engine bulid. He has a 1000hp supra that runs on E85 alcohol. He is building a 2jz supra motor with stock compression and ridiculous boost levels "30psi+". Because E85 has less problems with detonation. He was trying to get me to run E85 in my car.
I decided to go lower compression and stick with gas as my engine wont be sleeved for crazy horsepower and I drive long distances where E85 may not be available.
Old 05-01-2012, 11:50 AM   #12
^ Plus the work of changing out fuel lines and such, it's a pain. I opted not to go that way also. The compression you've chosen isn't a lot lower, it won't be very noticeable off boost, and you'll be able to run more boost. It will make tuning easier.
Old 05-01-2012, 07:23 PM   #13
pimp my yaris
C'est la vie
Life at the center of the Yariverse
Old 05-04-2012, 01:30 AM   #14
Schizoprenia
is that the picture of a used engine you got to replace the original broken one?
how much does it cost for a block like that, over there?
Old 05-04-2012, 07:46 AM   #15
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
i got a 2008 motor out of a sedan for $800 with 38K. it was complete from head to pan.....
Old 05-01-2012, 07:25 PM   #16
pimp my yaris
C'est la vie
Oil change. THE HARD WAY.
Old 05-01-2012, 07:33 PM   #17
pimp my yaris
C'est la vie
Old motor boxed up. Head good, Bearing journals and crank good. I will save her for a rainy day and then mabe send her out to get sleeved at Golden Eagle. They can remove the part of cyl. 3 that cracked off and make her stronger then ever.
Oh, if I only had more money. Someday
Old 05-01-2012, 09:25 PM   #18
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Those storage tubs are great, I use those a lot for motor teardowns!
Ptuning.com
