Old 04-30-2012, 07:28 PM   #1
Can you post a few more pictures of the new stock header? Looks different than previous years.
Old 04-30-2012, 10:33 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yes, it's very different.
I'll post detailed pics tommorrow when there's good daylight. It's a really strange combination of tubing with a falafal like shell molded over them with a welded seam all around the edges. It must work pretty well overall, because the factory has the luxury to test its designs to see what works best over the widest range of driving conditions.
Bottom line: I'm totally pleased with the low end torque of this Tri Y header. It outperformed my expectations.
Old 04-30-2012, 11:12 PM   #3
vten
its the same design witht the one I have since a couple years ago .
it's a good buy
Old 05-01-2012, 07:47 PM   #4
tooter
play every day
tooter's Avatar
Hey Cali,
Here's some pics of the 2012 OEM header. Note the horizontal bulges connecting the outer two tubes...
...and on the other side horizontal bulges connecting the inner tubes. Toyota configured their OEM header a semi-tri y design although none of the tubes are discretely separated from each other like the WR header.
The inside is all one open smooth undulating chamber.
What had appeared to be tubes welded inside the engine flange are actually the two halves of the formed metal header shell. Each side makes up 180 degrees of the tubes.
It reminds me of those hot pressed sandwich makers that seal the sandwich all around the edges, except in this case the sandwich is welded. Side view shows the full length weld.
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 06:40 AM
weapon R header aucorium Yaris TS Talk 18 10-10-2012 11:37 AM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 08:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 05:26 PM
Weapon R header noise? bladesmith6 Performance Modifications 4 10-20-2008 07:09 PM
