![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
Wheel spacers
I've done some research on internet to find some good wheel spacers and have not find. About 20mm.
Do someone have them on their car ? I have a 2008 HB. Thanks!
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
I run the 13mm Penguin Garage hub spacers for the rear... as the rears are terribly sunken in compared to front. May not be what you are looking for.... but lots of people on here have them.
and no complaints :) Here's their website: http://www.penguingarage.com/HubSpacers/Spacer.html
-Jen <3 ![]() Quote:
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Check out H&R Trak+ spacers, I'm sure Garm at Micro Image could get them for you.
http://www.trakplus.com/what racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 Last edited by racerb; 05-07-2012 at 08:12 AM. |
Awesome, guys !
Is it hard to install ? since I don't really know how to dissemble the brake setup. Thanks again ;) |
Not sure which one of us your asking, but if you have never done this sort of thing before. It might not be a bad idea to find a trust worthy Mechanic to do the work for you. The Penguin Garage unit requires removing the hub assembly, while the H&R spacers require installing longer studs. Both jobs take a certain amount of mechanical skill and proper tools. Which ever direction you chose, it will make a difference in track and fill out the fender wells.
racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
The PG spacers were actually fairly easy to install. The hardest part was getting the drum off to get at the bolts. Read up on the PG spacer threads around here to get a feel for it.
play every day
My rims didn't clear the front disc brakes so I needed to order 5mm spacers. I got solid ones with a 54mm hole in the center to clear the front hub.
Free Mustache Rides
hey, you guys mind posting a couple pics in here so i can get an idea on what size i should get?
#9 | |
Only Happy When it Rains
Colin Chapman disciple |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
^ Hub spacers, I don't think so, although those do look pretty similar to our design.
Wheel spacers, yes. |
I'm about ready to order a set of the Penguin Garage hub spacers just to see if they will also fit my '87 Celica rear hubs. That car has alot more space between tire edge and the fender lip and with standard offset rims even my 205/50/15 Toyo RA-1s rub the strut housings. I got away from crash bolts on the rear by making my own camber plates and can still get rub. Look forward to giving this a try and letting the world know if it works for other Toyota chassis!
Camber plates and strut adjustment knob...... ![]() ![]() Home built coil-over strut housing....... ![]() racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 Last edited by racerb; 05-10-2012 at 09:17 PM. |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
I've always wondered if you get some spacer do you have to get a alinment?
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
Anytime you mess with the suspension components, it's best to get an alignment.
hey if you can, measure the bolt spacing for the yaris hub while you're at it! I'm also interested to see what other cars are compatible with our rear hub (like certain gm cars with the 1st gen vitz)
#15 | |
![]() racerb
play every day
The bolt spacing is 4x100mm. Any spacer with that pattern and a 54mm hole in the center will fit.
He means the hub bolts, not the lug bolts. :)
Here you go: Yaris hub bolt measurements
| 25 mm Wheel spacers | Rnankoo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 24 | 03-22-2011 07:58 PM |
| Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed | RedVitz | Photo-Video-Media Gallery | 18 | 10-09-2010 03:36 PM |
| Installed 10mm PG spacers on a 15x7 +25 wheel | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-27-2009 07:10 PM |
| Steering Wheel Spacers? | BassAssassin | Cosmetic Modifications (Exterior/Interior) | 0 | 08-12-2009 12:52 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
