Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-07-2012, 10:31 AM   #1
kaemong
Drives: yaris 2008
sir, tanung ulit ako..kahapon pinahigpitan ko engine belt ko kasi maluwang at maingay sa petromin dito sa Malaz, pinalinis ko na rin ang carborator ko gumamit ako ng acdelco X66A. napansin ko umilaw na ung Fault indicator ko sa dashboard? paanu ba maalis un? bakit kaya biglang lumabas yon?
kaemong is offline   Reply With Quote
Old 05-14-2012, 07:41 AM   #2
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Sir try mo tanggalin ung positive at negative terminal ng battery at least 5mins. to reset the program...
Saka add ko lang, walang carborator ang yaris
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-15-2012, 09:47 AM   #3
kaemong
Drives: yaris 2008
salamat po sa reply...sige subukan ko yang suggestion nio, naaborido kasi ako dun sa fault indicator...
eh saan kaya nila ginamit ung pinabili nila sa akin na ACdelco X66a? hindi ba carborator yong parts sa pagitan ng Engine Filter, kasi dun nila inispray. wala kasi ako alam sa makina.
Old 05-16-2012, 03:11 AM   #4
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
ung ACdelco X66a card and choke cleaner ito, iniispray ito sa loob ng TB
( throttle body), habang nag rrev ang makina.. ito ay remedyo para sa taas baba ng rpm ( rpm hunting ang tawag dito ng toyota). ung fault indicator sabi nga ni duke pwede ireset kapag tinanggal mo negative cable sa battery then kabit ulit after 10 minutes, pero kapag andun pa rin, baka kailangan icheck ang MAF at ung mismong TB.
syntax is offline   Reply With Quote
