#1 | |
Roadrunner Jr.
That being said...with all the mitigating factors added in...sure! You can hear the difference between amplifiers. I can as well. I still submit that the hearing difference has more to do with amplitude differences than with the other factors I mentioned.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 05-09-2012 at 02:37 AM. |
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
i like music
#3 | |
We may be able to test this I believe some of the different brands share the same build houses from across sea's, basically cookie cutter circuit boards and diff components. It would be a slap in the face if say the budget brand Audiopipe and another highend brand shared the same motherboard =) From there we could do the above test.
#4 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Not sure what you are talking about. At the moment I have 4 two channel amps that potentially I can use for full range amplification. All have their own @sound@. In a blind test I am pretty sure I will not only be able to tell the difference but tell you which one is working at the moment. There is a bunch of variables that affect the sound of your amp like class, standard/dual mono, type of pre-amp - conventional vs tube, quality and type of components like capacitors/ op.amps/wiring, etc. As an example below is one of the amps that I have -it is a pilot (test) version of EOS Verdi. Verdis that were later put into serial production (big word considering the total of 12 were produced) have different capacitors (white mundors) and differents tubes (mine are nos 1956 siemens, for a serial production nos telefunken were used).. components are very similar, but the amps still have different sound (easily recognizable) http://photo.qip.ru/users/tolmach/95112742/124385883/ Another illustration would be comparing the top line denon HUs DCT-1 and Z1 - the same dac and internal components, different RCA output CABLES at the rear panel (DCT-1 has silver ones) -couple 6 inch cables makes huge difference in sound .. so pretty much everything affects how amp will sound like I still agree with you that using time correction and electronic crossover changes sound. This was one of the reason why I moved to @passive@ systems. Last edited by TOLMACH; 05-09-2012 at 02:18 PM. |
| full range class D amps | patm | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-09-2012 09:44 PM |
