Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
if you are only lowering 1.4 you shouldn't have much problem unless you aftermarket rims and tires are a good bit larger in total diameter than the factory set up. I'm lowered 1.8 but I am using factory size tires and do not have any rubbing issues unless I have a friend weighing me down in the back seat. there should be a thread here some where that list the total diameters of some of the common size aftermarket tires and it tells you how much over factory specs they are.
