Old 05-15-2012, 05:04 PM   #1
craigq
Drives: '07 Yaris, '12 GLI
Get a second person to have a listen at both of the rear wheels. If the noise is coming from there then it's likely that the rear drum brakes need lubricating.
I did mine a while back and did not take pictures, but basically follow the rear brake part of the FSM (starts at BR-59), jack the rear up, use some axle stands, remove the rear wheels, then the brake drums.
The FSM then shows where to apply "high temperature grease" and "lithium soap base glycol grease". I only applied some synthetic high temp grease in the outlined spots for "high temperature grease", reassembled (follow the FSM, there's a section about adjusting the brake shoe clearance), and no more squeaking.
EDIT: I wouldn't blow out the area with compressed air, but that's just me. Non-chlorinated brake cleaner and a rag while wearing some gloves. I know enough mechanics/automotive painters with cancer and other health problems that I like to attempt to limit my exposure to these chemicals/particles/dusts etc.
craigq is offline   Reply With Quote
break, squeak, yaris
Brakes Squealing! cmkennedy New England 1 10-30-2011 07:08 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 11:20 PM
Strange Noise and Iffy Brakes – HELP! ceilingwalker DIY / Maintenance / Service 5 06-07-2010 08:03 PM
ABS?, Grinding Noise When Brakes Are Locked!??? p0pNfr3sh DIY / Maintenance / Service 3 03-03-2010 06:22 AM
Noise from the drums.... Lafiro General Yaris / Vitz Discussion 18 05-22-2009 10:49 AM
