Old 05-09-2012, 02:30 PM   #55
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
Lexus = expensive Toyota. basically anything fancier than an Avalon is a Lexus.
Old 05-12-2012, 10:29 AM   #56
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Its time to get serious. Unfortunatly I am still waiting on one crank main bearing that is coming on a slow boat from Japan. These rods look incredibly strong.
pimp my yaris is offline   Reply With Quote
Old 05-12-2012, 10:32 AM   #57
^ I haven't been able to break one yet.
Old 05-12-2012, 01:06 PM   #58
Focus_Sh1ft
Focus_Sh1ft's Avatar
Those are easily twice the size of the normal rods
Old 05-12-2012, 01:33 PM   #59
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Pauter rods are definitely one of the best! I was trying to lay my hands on them when I first started my build but then somehow settled for Crower.
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 05-12-2012, 01:58 PM   #60
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by ROCKLAND TOYOTA View Post
SO your saying that lexus(TOYOTA) uses better grade materials on its vehicles??? you do know its all the same stuff right....
So in other words you are saying that the Lexus that comes stock handling over 2 times the horsepower is merely handling that because it has "bigger" parts due to larger displacement? If that is the case then I digress however I would be surprised and saddened.
Old 05-12-2012, 02:35 PM   #61
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I LOVE shiny auto parts.
Old 05-15-2012, 08:38 PM   #62
pimp my yaris
C'est la vie
It looks like I should get my parts in by the end of the week. Time to start check list. Cylinder hone, check assembly lube, check, plsti-guage check. I am already looking at new turbo's and planing a 3" downpipe from hell. Not yet sure I can make it fit yet.
Old 05-15-2012, 09:57 PM   #63
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
the engineering and the math is different. But I'd be shocked if the alloys are different. Most of Toyota's v8's are even all aluminum now. Only the IS F and the LFA mention anything other than aluminum.
There is a reason people can push 30 or 40 more horsepower through the car easily, and only really experience problems at over double the stock horsepower.
There is also a reason the 2JZ can push out all sorts of insane power levels.
Colin Chapman disciple
Old 05-15-2012, 10:07 PM   #64
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Do it, 3" dp will fit, depends on turbo outlet location. Motor mount inserts help ease clearance worries.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 05-15-2012, 10:17 PM   #65
TURBO YARIS
Drives: Yaris
What did you mean by this " Most of Toyota's v8's are even all aluminum now. Only the IS F and the LFA mention anything other than aluminum."?
TURBO YARIS is offline   Reply With Quote
Old 05-15-2012, 11:49 PM   #66
pimp my yaris
C'est la vie
What are these motor mount inserts you speak of? I could use something to stop the twisting. Im sure it will only get worse now on.
Old 05-17-2012, 07:53 PM   #67
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Check with energy suspension to see if they make them for the Yaris. That is what I use.
Ptuning.com
Old 05-19-2012, 07:29 PM   #68
DentGuy
Drives: Supra
3/4 of the shortblock is back together.
DentGuy is offline   Reply With Quote
Old 05-20-2012, 10:52 PM   #69
pimp my yaris
C'est la vie
Progress and set backs this weekend. I finally recieved all my engine bearings from Toyota on thursday. This weekend I set out to build this short block with a friend "Dent Guy" who built his own 1000hp 2jz supra motor. The instructions for the rods say U may need notch the block for the rod clearance on small bore engines. It took three attemps to remove enough material to clear the rods during crank rotation and still have the indicated 1/16 clearance remaining. And this also means cleaning the block and oil passages three times and R&R the crank three times. This took a long time. On final assembly the very last piston compression ring on the last piston broke while my friend was very gently sliding it over the top of the piston. THAT SuCKED. I was hoping to get this thing running by today or tomarrow. So now I will be ordering a ring set for one piston from CP on monday and hopfully having it shipped overnight to finish assembly on the short block.
Old 05-20-2012, 10:59 PM   #70
pimp my yaris
C'est la vie
more pics
Old 05-20-2012, 11:02 PM   #71
pimp my yaris
C'est la vie
more
Old 05-20-2012, 11:08 PM   #72
pimp my yaris
C'est la vie
This was my first attempt at notching the block. It was not nearly enough as seen by the assembled pic.
