Ahh.. battery code 'puzzle' solved while I was attending to unrelated Yaris items. I went into an AutoZone today for several non battery reasons. While there, I thought it would be interesting to know which battery code they show for my car, so I asked. It turns out their system shows more than 2 codes for my car, with two of the codes being 35 and 26R. The rep said the different codes showing will all fit and work just fine in my car. This led to a bit more discussion. It turns out that a particular code is not synonymous with a specific size, that there are multiple sizes within the same code. I shook my head. I asked (somewhat rhetorically) if it's possible that both a service writer and a technician at Wal-Mart would not know that there are different sizes within the same code re batteries. The AutoZone rep laughed and said it is entirely possible. I didn't write down all of the possibilities (nor have him scroll down to show more correct codes), because when I need to replace my battery I'm just going to get another Sears Plus Start 26R. However, If anyone needs a new battery and is in some location where they can't get a code 35, call or visit an AutoZone and they can tell you what else will fit and work properly.
#2 | |
In other words..... consider a #35 for example....... All the #35 means is that the terminals will be in the right position and it falls within the #35 specs for max hight, width, depth, etc which allows for some variations. So, not all batteries of a given number are all exactly the same but, they should still all be interchangeable. BTW, I believe that 26r and 35 are interchangable but, the 26r has less capacity. I don't know why Walmart said a #35 would not fit.... perhaps they had no idea what they were doing. Since the Yaris is only made in Japan and is shipped intenationally to different climates, perhaps that is why a 26r is listed also. BTW, just about all batteries brands sold in the US are made by only two companies, "Exide" and "Johnsons Controls" . Last edited by RedRide; 05-17-2012 at 09:38 PM. |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Lightweight battery install | Klink10 | DIY / Maintenance / Service | 11 | 02-28-2009 08:43 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
