Old 05-16-2012, 05:54 PM   #1
Yaristeve
Drives: 3-door hatch
Originally Posted by DonM View Post
There is an easier way to do oil changes - this is how I do mine......get a 8 foot length of 2x6 from Home Depot...cut it up into 4 pieces - 2 pieces each at 2 1/2 ft in length and the other 2 pieces 1 1/2 ft in length
Place each of the short pieces on top of the 2 1/2 ft pieces in the middle of these long pieces and nail them together - home made ramps that will never give out.....a heck of lot safer than relying on a jack.
I did the same, kind of. I made myself a ramp using 2 X 12 piece of wood. Cut it into three pieces of staggered length (IIRC, 3', 2', 1') to make a three-layer thick ramp. Ramps sold in stores are just too tall. I only made one to lift up one (left) side of the car...
Originally Posted by jambo101 View Post
I just go to the corner of the street where the sidewalk dips for wheelchair use and i drive the two rightside wheels up on the sidewalk,
Shouldn't you be/have been driving the two LEFT side wheels up on the sidewalk? The drain plug is on the right side of the car and should be the low point...
Old 05-17-2012, 03:45 AM   #2
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Actually the road is slanted for drainage purposes so running the right side up on the curb makes it level but i'd say its whatever you prefer as its just as easy to run the left wheels up on the other curb..
As for a cop giving you hassle for an in street oil change? maybe if he happens by in the less than the 15 minutes its going to take and depending on his mood i doubt you'd get to much of a problem even if you were observed,if theres a huge puddle of oil on the ground at that time it might be a different matter or if you live in a deed restricted community you may have a problem..
Have Yaris will travel..
Old 05-17-2012, 02:54 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
even then, if you can prove you live nearby and it is obvious you are draining the oil into an approved container and nothing has spilled I highly doubt a cop will care.
Colin Chapman disciple
Gwasabi (Yoshi) - Photo-Scavenger Hunt! gwasabi Photo-Video-Media Gallery 24 03-07-2009 11:23 AM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 06:02 PM
New car shopping - long post littlecarlove General Yaris / Vitz Discussion 19 11-01-2006 10:58 PM
