Old 05-19-2012, 02:00 AM   #1
Calogero
Calogero's Avatar
Drives: Toyota Yaris
Originally Posted by tooter View Post
Does anyone here run a TRD intake... and if you do, could you post some pics of where the air box is located when it's installed?
Thanks!
I like the long straight intakes for better low end... but not the fact that the car needs to be disassembled just to service the air filter.
I have the TRD cai and the instructions are straight forward.
The air box I assume you mean where the cone filter is located between frame
Rail an wheel well.
1)The tubes are a snap to install
2)all you have to do Is jack the car up and turn the steering wheel left completely.
3)look inside the wheel well on the liner youll see buttons(center removal of button with flat head screw driver you do not have take apart snaps slide middle out and pull entire button out) you have two snaps to undo and one bolt philips no 2. (star) underneath that holds the lining of the wheelwell to the bottom of the bumper once that's of you can peel back liner And install the cone filter . Remember to disconnect negative battery terminal when you install. Sorry no pics but honestly it is a really simple install take your time and enjoy the experince .
Lead, Follow or get out of way.
Thomas Paine
Stage One Yaris
TRDsway bar, TRD springs & shocks, TRD
Quick shifter kit, TRD CAI, TRD oil & coolant cap
Microimage light crank pulley, Agency Power steel braided brake lines.
Calogero is offline   Reply With Quote
Old 05-19-2012, 12:02 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Rail an wheel well.
Thanks for the info, Cal...
Is this your TRD intake?
These are listed on ebay.
Do you have any trouble with water? Where I live, we occasionally need to drive through flooded roads.
Old 05-21-2012, 10:23 PM   #3
Calogero
Calogero's Avatar
The intake image is not the one in the Yaris.
Trouble with to date no and I do not expect any water problems either.
Injen is an excellent brand I had it on a corolla great all around.
I chose TRD because that's what I wanted. pick what you like research and enjoy
Flooded roads. I agree with others short ram is best water higher than14" and your engine is drinking water. Cheers
Thomas Paine
Stage One Yaris
Old 05-21-2012, 10:40 PM   #4
tooter
play every day
tooter's Avatar
Thanks for letting me know.
Yes, unfortunately that has to be a consideration because we live in a flash flood area. If I do get anything it'll likely be a short one. A year ago my wife's car was almost floating.
FS: Many goodies, stereo, speakers, AEM intake, TRD filter, parcel, LED lighting Littlefoot Items for Sale by private party 1 05-09-2010 10:28 PM
FS: TRD Cold Air Intake 33OH Items for Sale by private party 14 05-15-2009 03:30 PM
Pics of Recaro SRD's installed... reznunt Photo-Video-Media Gallery 11 09-10-2007 01:42 PM
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 04:12 PM
