Old 05-21-2012, 07:17 PM   #1
The total capacity if the U340 AT is 5.68 quarts, but when you pull the drain plug only a bit over 2 quarts will drain. Pulling the AT cooling hoses and draining them and the AT cooler portion of the radiator drains about another quart. The remainder stays in the valve body and the torque converter.
Old 05-22-2012, 09:55 AM   #2
sansag13
Drives: 2009
Thanks Master Scott,
Need little bit more detail here.
1)Where cooling hose is located?
2)How can I suck the ATF out of it? With some suction pump or when I turn on the car, it will pump out it for me.
sansag13 is offline   Reply With Quote
Old 05-22-2012, 10:04 AM   #3
The AT cooling hoses are the two small (~1/2" in diameter) hoses that both go into the bottom of the radiator (as opposed to the pair of 2 1/2" or so diameter ones for the coolant.
You can loosen the pipe clamps that connect the rubber hoses to the metal pipes and simply drain both sides. No suction is required, and you definitely should not run the transmission to pump it out.
Old 06-03-2012, 10:10 PM   #4
sansag13
Drives: 2009
Hi Scott,
I have got 7 quarts of ATF WS from toyota this weekend. However when I went below the car to open the ATF plug, I could not figure out which kind of tool I should use to open it. Looks like it requires big hex key (bigger than 5/14"). I tried to look for that kind of hex key in local wall mart and home depot but couldn't find one. I would appreciate if you let me know which kind of hex key you used and from where can i get it.
Old 06-03-2012, 10:16 PM   #5
Hi Scott,
As I mentioned in post #9 above, it requires a 10mm Allen. You can purchase one with a 3/8 socket from an auto parts store.
Old 09-03-2018, 07:49 PM   #6
Tedtalker
Drives: 2007 Yaris Sedan
I just performed a drain and fill with the Yaris jacked up on the drivers side only. a little over 3 quarts came out of the drain hole. Noticed when I let the jack down it quit draining. I jacked it right back up on drivers side and fluid started draining again. That's a tip from me to others here who will drain and fill. Over 3 quarts came out of mine. Yes indeedy!
Yaris - It's A Car !
Tedtalker is offline   Reply With Quote
Old 09-04-2018, 05:45 AM   #7
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That's a great tip. Coming up on a drain and fill soon, so will give that a try. Thanks.
Old 09-09-2018, 09:05 PM   #8
Tedtalker
I also noticed an increase in MPG. I should have done it sooner! I used Valvolene Maxlife synthetic Automatic Transmission Oil from Wal-Mart. Toyota WS compatible. Tranny is silky smooth.
Old 09-15-2018, 02:14 PM   #9
barongan
Drives: m5
interesting thread, I have the same question
barongan is offline   Reply With Quote
Can non-Toyota dealers/repair shops replace transmission fluid w/o "special equipment lejulie DIY / Maintenance / Service 10 10-23-2011 07:35 PM
So when DOES the transmission fluid need to be changed dutchy999 DIY / Maintenance / Service 12 09-06-2011 05:18 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 04:01 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
