Old 05-21-2012, 08:00 PM   #1
sqcomp
Roadrunner Jr.
sqcomp's Avatar
So you've got the 6" Energy component set?
The tweeters will help stage height if they're up in the pillars. As far as aiming, look for a spot as close to the glass and more on axis since they're a smaller 20mm format and you're probably using the crossover that comes with the set.
― Thomas Paine
Old 05-21-2012, 09:18 PM   #2
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
What about powering them puppies up Sq ? What do you recommend ?
Old 05-21-2012, 09:57 PM   #3
razingman
Drives: 2007 ls liftback 5 door manual
I was thinking of getting an amp in a couple of weeks when I have the money for a great one and a sub, I care more for quality then noise
razingman is offline   Reply With Quote
reverse gear..quick question.. Yaris2910 DIY / Maintenance / Service 10 01-11-2011 05:14 AM
Quick Oil Question nickhjort Performance Modifications 5 04-27-2010 08:51 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
quick air filter question wingdood DIY / Maintenance / Service 3 05-11-2009 08:17 PM
Quick question.. harveyjai Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-21-2009 05:38 PM
