Old 05-22-2012, 07:43 AM   #1
spocksleftball
spocksleftball's Avatar
Drives: 2011 yaris
looking for small improvements
So I got a larger exhaust, sway bar, cai. Looking for the next incremental hp increase. What to look at is the question. I was thinking headers, but what are the benefits vs cons? Loss of low end torque would be very bad. Open to suggestions.
spocksleftball is offline   Reply With Quote
Old 05-22-2012, 08:07 AM   #2
Header, well, personally I always ran the stock one, but those who swapped theirs seem more than happy with them. Look around, there's been lots of discussions...
My choice would be a lightened crank pulley. If your car is manual you will feel a nice difference. It won't actually make your car much faster, but it will feel so much better to drive!
Old 05-22-2012, 12:33 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
^ Crank pulley and header are nice upgrades, I just did both of those last week. the pulley will help the engine spoil or rev better and easier and the header will help it exhale better thus increasing horse power. I can feel the difference in my car and the header also adds some higher rpm noise from where you can hear the exhaust rushing through it but after an axle back and a CAI it isn't easily noticeable. some ECU rests and some getting used to and my cars estimated whp will be between 106 and 112hp and fuel inefficiency will be creaping up on the 50mpg range average, right now i can get that high way easy will maintaining speed limits. I would suggest looking and seeing what stock header you have first and if you have one like mine in my
then get the pulley instead and hold off on the header but, if yours is like
Tooter's
then get the header. i suggest megan racing, biggest diameter and MI has a great price on it, also bet the stud kit it makes the install nice.
Old 05-22-2012, 12:35 PM   #4
Calogero
Calogero's Avatar
Drives: Toyota Yaris
Light pulley is nice.
But like so many have said make your car lighter
It helps ex: any thing in the trunk you don't need, perhaps rear seat removeal
Replace stock front seats with light weight race seats.
Lighter car better acceleration, better stopping and cornering.
Quick shifter is nice add on my 2cents
Lead, Follow or get out of way.
Thomas Paine
Stage One Yaris
TRDsway bar, TRD springs & shocks, TRD
Quick shifter kit, TRD CAI, TRD oil & coolant cap
Microimage light crank pulley, Agency Power steel braided brake lines.
Calogero is offline   Reply With Quote
Old 05-22-2012, 12:37 PM   #5
The Megan header will also pair up with another product we're coming out with, that I can't mention quite yet.
Old 05-22-2012, 05:12 PM   #6
403RS
#yyc
403RS's Avatar
Drives: BSP '07 RS 5dr LB
So when's the midpipe come out?
403RS is offline   Reply With Quote
Old 05-22-2012, 05:31 PM   #7
Golddeenoh
Golddeenoh's Avatar
^boom
Old 05-22-2012, 07:10 PM   #8
haha, nice. Very soon!
Old 05-22-2012, 10:33 PM   #9
spocksleftball
Drives: 2011 yaris
Frankly the centripital forces on the pully are such that at 3k rpm i doubt there is a dimes worth of difference in 12 or 20 oz. Seriously it is about torque and hp not essoterics at this poi t. The header I get, but withoutthe midpipe it has no tangible effect since the diameter is choked off...fluid dynamics within a cylinder not coolness determines flow rates. And if i did install a header that sucked more air, i would lose torque since my engines cannot suck more than normal without some induction force...i do not have money for a turbo at this time.
I know all the old school tricks, but none apply to the yaris...4 barrel carb, 3/4 cam, bored out with high compresion pistons, 4/11 rear end...blah blah blah.
I was thinking there was something, but nothing I see will do short of a turbo.
As for 50 mph...what? From a header? Dude that's called a bong, not a header...to get that mpg, he is doing 35 on the freeway.
I want to get more zip off the line, more torque in second gear...but I am poor. And Ive been drinking, so if this is harsh it is the beer talking...but you get the drift...
Old 05-22-2012, 11:15 PM   #10
The 1NZ doesn't make power yet at 3k no matter what. Even mine doesn't. However, the pulley will make a difference you can feel.
You are also forgetting a few things. Probably the beer. We could start with the weight of the car. A lightweight vehicle benefits more from small gains than a heavy one.
This was your original request --
Old 05-23-2012, 05:59 AM   #11
spocksleftball
Drives: 2011 yaris
Is there really a measurable difference in torque or hp with a weight change of that much? Seems incredible.
I think I just frustated that my database is obsolete. Otherwise id just drop in a new cam and lifter springs. Oh wait! VVTi.
The only issue I have with my yaris is that dead spot between first and second where it lags in normal driving. Now the more I think--as opposed to drink--about the problem, the less I really think I can do much about it. I still need to see the dyno data before I beleive in the pully.
Old 05-23-2012, 11:13 AM   #12
willygoodness
Drives: 09 yaris hb
had a couple mate that had the same model car. sr20de one had cat back exhaust... the other had header back... same intake, same ride height and same model
the car with header back exhaust was able to get to 210km/hr. the one with the cat back could get to 180ish... and cat back would lose acceleration from around 160ish
hope that helps with headers...
willygoodness is offline   Reply With Quote
Old 05-23-2012, 11:15 AM   #13
willygoodness
Drives: 09 yaris hb
^^ also both sr20de had low/ same'ish km on the odemeter
Old 05-24-2012, 12:03 AM   #14
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
you can feel the difference in the pulley set. The car feels lighter and it revs easier. Just like lighter wheels make a huge difference when you put them on, lighter pulleys do the same thing. As does a lighter flywheel.
People don't do these mods because they look good. They replace parts like pulleys and flywheels because they make the car feel faster, and they help more power go to the ground.
If you want to pay for the dyno pulls I'll have them dynoed. Holding both the stock and aftermarket pulleys in my hand the weight difference feels massive.
Colin Chapman disciple
Old 05-24-2012, 12:58 AM   #15
spocksleftball
Drives: 2011 yaris
So...no one has any proof of lighter pullies increasing anything? I have to pay for dyno cause no one has done it? Everyone simply assumes it works? Pa--lease!
Does no one question anything?
Old 05-24-2012, 01:43 AM   #16
Viperoni
Drives: 2005 Toyota Echo
After spending 5 minutes on google, here's a dyno of a full pulley set that gained a maximum of 4.5hp on a civic:
http://www.importtuner.com/powerpage...s/viewall.html
I have a lightweight flywheel waiting to go on, but im personally not sold on pulleys for two reasons:
1) the weight is already fairly close to the center, compared to a flywheel
2) You lose the harmonic dampener, if the OEM pulley has one (not sure if this is the case for the Yaris)
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 05-24-2012, 01:55 AM   #17
Pulleys aren't really going to give you a measurable improvement in horsepower, but you will feel the difference. In my personal opinion, it was the best bang for the buck mod I put on my car, made it feel far less sluggish. Following that would be a short shifter and associated bushings, also no HP improvement but made the car that much more fun.
Remember, horsepower is not the only thing that counts when driving a car!
If you're dead-set on seeing improvements on the dyno, then header is your best bet. DC Sport's seems to be the most well-liked, and seems the best constructed out of the available ones.
After that, getting more horsepower gets tricky. You could open up your exhaust more with some custom piping, or use a Camcon unit to tweak the VVT-i, find Jason@SportsCar's thread on this, they managed to squeeze out an extra 13 or so hp. More than that, and you'lll have to go all out with a high compression engine build, or go turbo. Either way you'll also need some proper tuning, so your wallet's the limit!
Old 05-24-2012, 03:32 AM   #18
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Tooter's
What's the matter?... don't like my falafel header?
2010 yaris hatch thoughts and some improvements enviri New YARIS Purchase Forum 2 12-18-2009 04:37 AM
