POWER WINDOW POWER SOURCE IN DOOR PANEL?
I have the door panel off and see that there is round unused 4 prong plug that is not used on the upper front part of the door panel. Has anyone used this plug or wires to install the power window kits. Is it just installing the fuse so there will be power to these wires.
I've check several of the threads and don't see to find anything |
Why don't you just wire it to the fuse box under the driver's side dash?
![]() ![]() ![]() ![]() Drives: 2007 Yaris manual dark silver Join Date: May 2006
ya really
7 Color Tach Fujita Intake Momo pedals Shift knob and boot. Full TRD SSK. Blitz exhaust Megan Lowering Springs (Next is DC Header) |
![]() Drives: 2007 Yaris Sedan Pacific Blue Join Date: Oct 2006
according to the manual I just downloaded, that is the plug for the power package, not just the windows. All of the following hook into it, and not sure if aftermarket kits will eventually use this or not:
G 1 Power Window Master SW G 2 Outer Rear View Mirror (LH) G 4 Power Window Regulator Motor (Front LH) G 5 Door Lock Assembly (Driver’s Side) G 6 Speaker (Front Door LH) G 7 Door Lock Control SW (Driver’s Side) |
thanks for actually answering the question. why run new wires if the already exist. is the manual you downloaded the info on this forum?
thanks in advance |
Here you go: http://www.etimago.com/yaris/repairmanual/
You can download whichever section you need, or do as I did and dl the whole thing, and burn it to a cd. Just don't buy it off ebay, get it here instead. |
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
