![]() ![]() ![]() Drives: Black '08 Yaris Hatch S Join Date: Aug 2011
how was the mpg in the xA? ( i don't know jack about them)
-Will- |
Overall it was about the same...despite the the higher highway RPM. There is almost nothing compatible between the xA and the gen-1 Yaris aside from wheels....though the xA can accommodate wider rims and tires. Intakes, exhausts, suspension parts will not interchange. But there are parts-o-plenty out there for the xA. The biggest powertrain differences between the xA and Yaris are the xA's lower final drive (in the manual tranny) and it's cable controlled throttle.
If only I had known where I'd be...I'd still have that xA.
If you want to enjoy your car, stay off of the internet. |
![]() ![]() ![]() Drives: 2007 Liftback Join Date: Mar 2012
I had a similar debate back in March, I really liked the xA, but the Yaris left me cold.
However, I ended up finding a Yaris with all the options I wanted, newer, with lower miles than the xA I wanted to buy. - Yaris has a less busy ride, especially sedans - Yaris is geared taller and is less noisy on the freeway while returning better economy - xA isn't available with cruise, unless you go aftermarket (strong deciding factor) - Yaris is a newer, stiffer platform. I remember being slightly turned off by how buzzy the xA was on the freeway; at around 75MPH it was turning nearly 4K RPM, IIRC. The xA does have sharper steering, but the Yaris is the better handler; it's kinda soft but it grips better. The xA is fairly tall feeling, and some corners it can be a bit unsettling. |
Also, the Yaris has better freeway economy. I get around 42, and the xA is a little worse.
I felt like my xA was the better handler, for sure. But that just my opinion.
| For Saie: Tanabe springs 2008 up Scion XD 2007 up Toyota Yaris | KSIbucky | Items for Sale by private party | 0 | 07-13-2011 02:11 AM |
| Toyota Yaris Scion xB xA Stock ENGINE COVER OEM | justoneyaris | Items for Sale by private party | 11 | 12-04-2008 08:05 PM |
