Old 05-30-2012, 08:18 PM   #1
roneezy360
roneezy360's Avatar
Drives: Toyota Yaris 2007
Originally Posted by Qmobile View Post
You can shift a auto......I do least. But you have the optoin of not ALWAYS shifting
Shifting an auto wont damage your vehicle in any way will it? I actually tried this out today and its kind of fun, but I looked it up online and was told its better to get a manual valve body and doing this will wear out my transmission faster because of all the heat.
roneezy360 is offline   Reply With Quote
Old 05-31-2012, 10:22 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It certainly cannot help it. The car just wasn't designed for it, and more importantly the computer wasn't either.
Colin Chapman disciple
Old 06-02-2012, 06:27 PM   #3
MadMax
MadMax's Avatar
Bullshit. If Toyota didn't want its customers to have the ability to shift their automatics into other gears, or if there was any risk of damaging the transmission in doing it, they wouldn't have designed the transmissions to allow it! Cars would have Park, Reverse, Neutral and Drive only; but as they are you can shift down to three other gears in the Yaris.
There's no harm in manually shifting an automatic, other than using more gas...
Old 06-04-2012, 02:54 PM   #4
why?
why?'s Avatar
Drives: Yaris LB
not true. There are certain situations where the different gears are extremely helpful. As in steep hills or terrible weather or the like.
But pretending it is manual is silly. There is a reason you spent $1000 extra for another computer.
Old 06-04-2012, 03:30 PM   #5
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Yep, I most always manually shift mine on steep hills (I'm looking at you, Tennessee) or it tends to hop back and forth between 3 and 4.
Yeah, because manual sedans are practically impossible to find :(
I'd have got a manual if I could, but I couldn't, so I have an auto. I have a proper transmission in my project truck, so that makes up for it I guess :P
Old 06-04-2012, 04:59 PM   #6
david_827
Drives: 07 Yaris Sedan
I was going to say the same thing, also isnt the L supposed to be used for towing????
david_827 is offline   Reply With Quote
Old 06-04-2012, 05:17 PM   #7
why?
why?'s Avatar
Drives: Yaris LB
Almost positive the Yaris is not rated for towing in the US. It is probably a lawyer type thing as it is rated around 800 lbs in other countries.
L is basically 1st gear. Really bad weather or really steep hills or soft dirt or sand or generally unusual conditions are the only times you should shift an auto. Especially one which has received a lot of praise on these forums for being a well thought out and logical machine.
To put it simply there is a reason F1 cars are pretty much all automatics.
Old 06-06-2012, 03:55 PM   #8
dragoonmc
Drives: 07 hatchback
They are manuals with paddle shifters because there is no room for a shifter in the car and the transmission is on the other side of the engine from the driver.
dragoonmc is offline   Reply With Quote
Old 06-06-2012, 11:58 AM   #9
MadMax
MadMax's Avatar
Really? Because in 3.5 years with an auto there hasn't been one situation that it couldn't handle whereas a manual could.
It's great to state your opinion, but don't confuse it for fact. There is no reason not to manually shift an auto other than fuel efficiency. It does not, as you claim, hurt the transmission (it shifts the gears anyway, just on its own) and there is nothing "silly" about it except for the fact that manual transmissions are not capable of doing the same.
What is "silly" is those thinking they get more "performance" out of a 105 hp car with a manual!
07 YARIS Liftback FOR PARTS benjomothians Items for Sale by private party 12 02-07-2012 01:53 AM
OEM PARTS NEEDED!!! JBougie Willing to Buy by private party 5 09-16-2011 01:37 PM
07 YARIS Liftback FOR PARTS benjomothians DIY / Maintenance / Service 0 03-28-2011 01:10 PM
Oregon intrudce Bill to Prohibit Sales of Aftermarket parts IllusionX Off-topic / Other Cars / Everything else Discussions 10 02-14-2009 09:29 PM
Aftermarket Parts Interest? Fluid Motorsports General Yaris / Vitz Discussion 27 11-09-2008 12:00 PM
