![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
switching back to natural oil?
i am currently running syth oil for 6 months, and 6 months only and now I am thinking to switch it back to toyota oil because of the price. Is it ok for me to do so and if the toyota oil is really that bad?
Only Happy When it Rains
what type of synthetic? Was is just a mobil type that is still based off of real oil or a total synthetic? If just a normal synthetic than you can just switch whenever and it will not matter.
Toyota oil is fine, heck most oil you can buy at a Wal-Mart is fine.
Colin Chapman disciple |
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
If price is a problem Canadian Walmart's have their SuperTech branded conventional oils on sale this week for $6.
it says mobil1 5w30 syth, not sure if it based of real oil? it's the one most people use
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
You can switch back to conventional. Conventional oil is fine. If you like the Toyota brand oil, it is perfectly fine stuff.
For that matter, any 5w30 motor oil that meets the American Petroleum Institute's current standards will work. The current rating is "SN," but if you come across some "SL" or "SM" oil, they will be OK, too. Any API approved 5w30 will provide the basic lubrication that your engine requires. Some brands might be better than others, but all should be "good enough." |
Mr. 155 and climbing
What is your drain interval?
#7 | |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
With the synthetic oil you can actually pay less for it than regular oil when you use extended drain techniques. The synthetic oil is far superior for wear and tear and if you use the 0w5, you can even get better gas mileage. With conventional, you have to change the oil at 5k miles. With synthetic, you can go 10 to 12k safely and have better protection. Its your car, but synthetic is just too superior an oil and saves you money. And it will help your engine get past the 200k mark with flying colors!
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
^ I was gonna say a lot of the same, but thy seem to have their mind made up.
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
I run only synthetic oil in all my Toyotas, change it at around 7,500 miles each time. But as others have said you could safely go 10,000-12,000 between changes. When I used to sell Amsoil, we would recommend changing your filter at 12,500 and topping up the oil, then not totally changing oil until 25,000 miles. This was after flushing your engine of all contaminates and installing Amsoil pure synthetic oil and an Amsoil filter. I run Valvoline pure synthetic now and a Fram oil filter and most times the oil still looks like new when I replace it. To be ohnest the real key with synthetic is the quality of your filter, you could easily just change filters, top up your oil and keep right on going for twice the distance I'm currently going between changes.
Oh and by the way my 3 daily/weekly driven Toyotas have 96,000, 176,000, and 195,000 miles on them respectively. In fact I sold a '94 T-100 I owned a few years ago with 240,000 miles on it, which also ran pure synthetic and it still ran like a new engine the day I sold it!!
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
If you are thinking you will get better gas mileage using synth think again. I drove 5200 miles to AK from NJ on regular motor oil and returned the same way using synthetic. There was no difference in gas mileage over 5200 miles.
Also you will void your warranty if you dont change your oil according to the owners manual. Also see below.
#11 | |
This is a debate that can go round and round, but there has been plenty of independent studies out there showing that synthetic has several advantages over conventional oil one of which is the ability to move away from the reliance of fossil fuels.
#12 | |
play every day
#13 | |
So you are saying that you only bought the Yaris for its looks/handling and not the FE that it provides you over other subcompacts out there?
#14 | |
play every day
![]() I'm a genuine cheapskate and take pride in buying the lowest priced new car on the lot. But not directly for the reason of trying to reduce dependence on fossil fuels. That's just a side effect of frugality.
#15 | |||
#16 | |
Its like the Chevy Volt and the Nissan Leaf. They were crazy to bring those cars to market at, what, $50,000. I hope they crash and burn. But if I see recycled oil for FREE Im there! Hey maybe there'll be Volts for free!
#17 | |
Why do we have these crazy rebates on G-Oil and the half-recycled Valvoline? Because they have to almost give it away to get people to even think about trying it. Oh well, I guess it's the best of both worlds. I get a major rebate and I get to feel warm and fuzzy about my environmental friendliness. |
#18 | |
As for being a "Mr. Moneybags" sure on my replacement motor that is going on right now I am throwing a guy some cash for assisting me, but all in all the bulk of the shops that I had talked to were quoting me between 400-600 for the installation and you can get a solid 1NZ from car-parts.com for as low as 300. If you do the work yourself or have someone you know pitch in that install can get a lot cheaper and you would learn much more about your car. The Yaris, Echo, and Tercel are some of the most simple modern era vehicles to learn about with exception to the intricacies that have become commonplace in the ECM/ECU. Thanks BTW for making it personal...that is outstanding. I agree a lot with racerb's statements actually. My opinion when it comes to operating anything is that I don't believe in people just being "users" of something. If you are on a computer you had best be able to use the thing without having to constantly pay someone else to fix the problems that you create on it. I take the same approach with vehicles. Take control of the thing. It is an investment. If all you do is short driving jaunts or low speed driving then that is great because it serves the purpose that you have, but personally if you have a vehicle for sale and tried to tell me that "hey, I only drove it slow and short trips so what I dump in it for lubricants shouldn't matter" then I would walk away and purchase elsewhere. The main reason for this is that short trips are actually the most taxing on an internal combustion engine regardless of whether or not you baby it or drive it like you stole it. Folks traditionally like to ask a premium for their trade-ins or private sales because they babied it or didn't run it hard. You want to get a premium return then treat it like racerb said...like an investment. In the long run synthetics can save you money, time, and grief, but that is just my perspective I guess. And oh yeah...I have been driving cars, trucks, motorcycles, and ATVs for 22 years so I am not too far behind you in the rearview.
| Is it safe to change from synthetic oil to regular oil | hero | General Yaris / Vitz Discussion | 18 | 02-21-2010 10:51 PM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| When should I start using synthetic oil?? | trwxxa | DIY / Maintenance / Service | 68 | 06-29-2009 06:16 PM |
| HELP!!! I went back to the service center yesterday for the 7th time in 2 months! | Meldav86 | General Yaris / Vitz Discussion | 27 | 08-21-2007 09:04 PM |
