Old 06-04-2012, 05:32 PM   #11
Originally Posted by Slasher View Post
Thanks CTScott,
The pics of the airbag clips made it super simple!!! I only had one real problems and that was removal/install of the horn pin on the old 4 pin connector... I broke it!!! I tried to force it!!! It's ALL MY OWN FAULT!!!! The removing the pin was almost impossible as there isn't a pin unlock like anything in the picture...
Well except for not having a horn, it works great on my 2012 3dr L 5spd
Also the lower dash panel under the steering wheel has an airbag, so that meant getting down on the ground and contorting myself to look under but the clutch switch was really easy to instal. The biggest bear was trying to pull off the tape from the harness to drop the connection for the clutch switch...
I just got back from the test drive and a refill... So 2 tanks and I am averaging 41.6 mpg I am pleased as I am still running 32psi in the tires and running A/C!!!
I am sure the CC will make the commute more tolerable... The aero hubcaps are enroute... And the next upgrade will be the speakers...
I apologize for the broken pin issue. For 2006-2011 Yaris I ship the harness with the horn wire installed. After the last couple of 2012 installs I didn't think that I needed to include it, as the horn wire was on the other connector, but as it turns out that is only for 2012's with steering wheel audio controls. For ones without the horn wire is still on the 4 pin connector where the cruise control connects through.
cruise control. 2012
