Old 06-11-2012, 09:33 AM   #1
You could also pick up engine RPM and wheel RPM signals and compare them to deduce gear ratios, no extra hardware necessary but some good logic needed!
Old 06-13-2012, 12:54 PM   #2
Yaristeve
Drives: 3-door hatch
Interesting solution! This would be the easiest since OBDII port would already have the info (but then you would need to figure way to crack the OBDII protocol). The logic should be fairly straightforward: you would only need to calculate MPH/RPM which will stay constant for each gear regardless of speed or RPM in that particular gear (unless you are drag racing with those flabby sidewall drag slicks)...
but...
Other than the cool factor, why not just glance down at the shifter? I can understand the possible need for a gear indicator for a sequential shifter, though (I often wish my motorcycles had a gear indicator)...
Old 06-13-2012, 02:43 PM   #3
TPA5
Wait, what?
Drives: NULL
Originally Posted by Yaristeve View Post
but...
Simply for the cool factor. No other reason haha.
TPA5 is offline   Reply With Quote
Old 06-14-2012, 01:18 AM   #4
Yaristeve
Oh, okay. That's what it's all about, having fun wth your car.
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
2006 Yaris 1.3 TR, 80k miles- Clutch need pressing to its end OR Gear change getshard planet DIY / Maintenance / Service 0 08-15-2010 10:20 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
