| View Poll Results: DRL: Low beam or -lamps - or not? | |||
| Yes, with low beam |
6 | 37.50% |
| Yes, with special DRL-lamps |
6 | 37.50% |
| No, no light at the day |
4 | 25.00% |
| Voters: 16. You may not vote on this poll | |||
#1 | |
![]() ![]() Drives: Look Signature... ;-) Join Date: Jun 2012
Thanks to all, who participate in this thread.Quote:
![]() This is too high for me. ![]() I guess you are a mechanic? ![]() ![]() I think the best for me would be if I would drive to the Toyota repair shop and will ask a mechanic how he would do it. If he will say, oh - yes - we need your car the whole day and it will cost 500.- €... I post a message here if you could explain it for me (dummy understandable) - and then I could explain it to the mechanic. #2 I read about the DRL-lamps are connected directly with the batterie. And they switch on if the batterie have 13.8 V - if I remember correct - the motor is running and load the batterie. If you have a low or old batterie it could be that the DRL-lamps don't switch on, because the 13.8 V isn't reached. Or they switch off and on and off and on during the travel. Or why happen this? Sometimes my car stay one, two weeks - because I have also a motorbike... so I guess this could happen then also at my car, because the batterie is low. I guess I should let install then the DRL-lamps also with 'ignition on' - that they will be always on. I hope this would be then also possible... |
#2 | |
I am going to be in Italy in a couple of weeks on holiday. You should drive down and we can wire them up for option #1 in the parking lot of my hotel. For #2, if they switch on automatically at 13.8 volts, then they would be fine, even when the battery gets old. The alternator puts out 14.1 volts when the car is running, so unless the battery was completely dead they would still work.
Thank you for the suggestion.
![]() Italy isn't so near... ![]() I guess the cash for the petrol will be much more than if I would let do it in the Toyota repair shop...
You have special DRL-lamps on your car?
If possible, maybe you could make two pictures, one with low beam and one with special DRL-lamps, maybe at least 50 meters (this are 164 feet?) far away? This would be super! So we could compare if they are bright or more bright than low beam... (better seen). |
| H4 Low Beam HID Kit HELP | SLOWSK8 | Cosmetic Modifications (Exterior/Interior) | 2 | 03-20-2011 09:50 AM |
| Yaris sedan low and high beam | jorizk | DIY / Maintenance / Service | 10 | 03-02-2010 09:49 AM |
| Fog lamps as back up low beams. | ellenbetty | General Yaris / Vitz Discussion | 114 | 10-22-2009 03:40 PM |
