Old 06-17-2012, 08:44 PM   #1
boggydee
Drives: 2009 yaris 4dr hb
hello ctscott, donesnt seem hooked up tho... would you happen to know wheere the terminals for the back window is hooked up on? so i could just splice and tap to that?
boggydee is offline   Reply With Quote
Old 06-17-2012, 09:03 PM   #2
They come through the door to the kick panels on a violet wire (one the other end, they are grounded inside the door).
That violet wire goes to pin 11 of Connector 4M of the under dash fuse panel.
From there they go through the 10A ID/UP/MIR HTR Fuse in the fuse box under the bottom of the dash.
That fuse is fed from the defroster relay and at that point (internally to the under dash fuse panel) is connected to the rear window defroster (which connects via black wire to pin 2 of connector 4F).
Heated Side View Mirrors goku87 DIY / Maintenance / Service 27 01-26-2016 05:23 AM
Unlinking heated side mirrors / rear defrost Alezius DIY / Maintenance / Service 9 11-03-2010 01:29 PM
heated mirrors on 09 model? DOMAV General Yaris / Vitz Discussion 34 10-27-2009 04:13 AM
Replacing manual mirrors with powered plz help MikeB DIY / Maintenance / Service 0 05-27-2009 09:55 PM
Will '09 Heated mirrors fit on an '08? goku87 DIY / Maintenance / Service 1 11-17-2008 05:39 PM
