Old 06-19-2012, 11:36 AM   #1
Originally Posted by Sedanades View Post
Hello jp -
From April to now it acted flawlessly. I gave credit to warm weather. Lately, it has been running overvoltage after starting, then it settles down.
I removed the alternator, disassembled the regulator and brush assembly, sprayed DEOXIT on all the contact points, reassembled the thing and bolted it back in the car.
No change. Grrrr.
Thanks for the idea CTScott, I will try that. Just follow the wire from the alternator to where it ends?
Yes, you can follow the wire up, or pull off the positive battery terminal and you will see where it connects to on the bottom of it. If you are seeing over voltage, then it isn't corroded contacts, but rather a bad regulator.
Brake warning lights !+ABS tomrom101 DIY / Maintenance / Service 40 12-29-2013 09:20 PM
"ABS" and "(!)" Warning Lights? mgoldhawk DIY / Maintenance / Service 4 08-08-2011 08:51 AM
Yaris ABS and Brake warning lights stay on vinny121 DIY / Maintenance / Service 2 01-31-2011 12:02 PM
