Old 06-19-2012, 08:42 PM   #1
Ball3rina
Drives: 2009 Toyota Yaris Sedan
Question Missing oil filter = engine locking
I purchased my '09 Yaris sedan from Carmax in March and have had no issues until this past weekend. I was 400 miles overdue for an oil change I was going to wait until Monday to do. I let my boyfriend drive and he accelerated heavily at a traffic light changing and the oil light came on and a puff of smoke came out. We turned around the block to get back and shut it off and it lost engine power and idled.
I got it towed and the mechanic said I was missing the oil filter which probably wasn't tightened enough when Carmax serviced my car. Either way, it looks like I have to buy a new engine and Carmax isn't helping, even though I am covered under their extended warranty.
Thoughts/suggestions? Prior, I had received no alert lights or noticed any heavy oil spillage. The car still won't start and makes a clicking noise from the engine.
Ball3rina is offline   Reply With Quote
Old 06-19-2012, 09:14 PM   #2
vten
if you didn't do anything to the car prior the accident, I would go back to car max and give them hell ...
oil filter is not a thing that we always check in the morning ...it'll be a different story if you're missing the oil dip stick .
talk to their manager and gradually to the top of the chain ...just my .02c
Old 06-19-2012, 09:28 PM   #3
Ball3rina
Thanks! Do you think a hard acceleration could have knocked it off if it was loose? It's definitely Carmax's fault but I'm going to have to sue because they are not budging.
Old 06-19-2012, 10:12 PM   #4
Wow! An oil filter can be hand tightened and will never come off, particularly since the gasket expands as the oil heats up. They must have barely spun it on. There is no way that this is your / your boyfriend's fault.
Old 06-20-2012, 11:18 AM   #5
barryware
I would find it hard to believe the oil filter un-screwed itself off. It would leak substantially after about 2 ~ 3 turns and the engine would run out of oil long before it finished unscrewing.
I would have someone look at it. It may be that the base of the oil filter is still on the car and the metal can of the filter blew off the base. That would indicate a defective oil filter out of the box. I would be interested to know what brand it was so I don't buy one.
In regard to your fight with carmax.. 1st find out what exactly happened. Is the filter base still screwed on? I would think that if they used a defective part in their service, they should be responsible, or at least the manufacturer of the part.
Good luck..
barryware is offline   Reply With Quote
Old 06-20-2012, 01:30 PM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I agree. There is something missing in this story.
engine start, oil filter, sedan
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Did I overfill my oil? zkay DIY / Maintenance / Service 10 06-20-2012 11:59 AM
Oil & Air filter change please help! JAMMAN1701 DIY / Maintenance / Service 2 04-01-2012 10:28 PM
Having trouble fitting the engine air filter 2007yariz DIY / Maintenance / Service 9 10-30-2010 12:23 AM
Longer Life Oil Filter? Yar Is Word DIY / Maintenance / Service 14 07-19-2010 07:35 PM
