Old 06-18-2012, 02:07 AM   #19
TOLMACH
Drives: soarer
Originally Posted by vten View Post
Did you mean the spring compressor when you referring to the struts tool ?
If so, you can find them at the local advance auto parts...the brand is arm pro if my memory serve me right :)
Thanks, I was advised to speak to the parts store- in fact found the tool that I need at one of the CanadianTire outlets - the problem is that it is difficult to find it on site (always rented to someone) and they do not make reservations (( (which is unfair)
Thinking about spending 30 bucks and bying one from ebay
Old 06-18-2012, 08:26 AM   #20
Its a tool you wont regret owning...
However, if you're like me and have friends who mod their cars, it'll get borrowed a lot
Old 06-19-2012, 02:15 AM   #21
Definitely a useful automotive tool!
Old 06-19-2012, 02:27 AM   #22
TOLMACH
Drives: soarer
thanks for advice.. ordered one from ebay
Old 06-20-2012, 04:33 AM   #23
TOLMACH
Drives: soarer
Update: my wife noticed today that the car became a firmer ride (asked me why does the car feel different).. I am happy!!
Old 06-20-2012, 05:57 AM   #24
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Do you have for Toyota Echo 2005 same like this.
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 06-20-2012, 11:45 AM   #25
TOLMACH
Drives: soarer
it is the same.. lots of stuff on ebay to choose from
Old 06-20-2012, 01:58 PM   #26
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Which tool did you order? Can you post up the link on eBay to the one you picked up?
Old 06-21-2012, 02:06 AM   #27
TOLMACH
Drives: soarer
http://www.ebay.com/itm/230668821185...84.m1497.l2649
just bought the cheapest one (30 bucks shipped to canada)
i like the lower hook .. in case the top one has issues with my coils I can still manage it (have couple ideas upfront)
Old 06-21-2012, 03:01 AM   #28
my2sense
Drives: 2007 Red 5dr RS
Ha, those spring compressors look almost identical to the ones from Harbor Freight:
http://www.harborfreight.com/macpher...-set-3980.html
which is on sale for $15 btw.
my2sense is offline   Reply With Quote
Old 06-21-2012, 03:07 AM   #29
TOLMACH
Drives: soarer
do they work with front yaris springs?
Old 06-21-2012, 07:44 AM   #30
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I went with a much more expensive option: buy a second set of spring retaining hardware. While it cost about as much as a decent set of spring compressors, I won't ever have to mess with one: each spring stays mounted on its own shock.
Old 06-21-2012, 08:08 AM   #31
Every aftermarket spring I've put on can be put on the strut without a spring compressor EXCEPT Eibach prokits
Old 06-21-2012, 08:55 AM   #32
CrankyOldMan
Indeed, but I'm going to be swapping out springs & shocks every fall/spring. This way I won't need a compressor to dis-/re-assemble the OEM springs twice a year.
Old 06-21-2012, 01:01 PM   #33
i did the same for a couple years...then i got sick of doing it twice a year and just run eibach sportlines year-round.
i run taller tires in the winter, though....gives me an extra 1/2" of ground clearance
Old 06-22-2012, 12:04 PM   #34
TOLMACH
Drives: soarer
Interesting.. what was different with pro-kits?
Just ordered myself a set.. hopefully this works for yaris.
http://www.ebay.com/itm/130621365599...84.m1497.l2649
Old 06-22-2012, 12:07 PM   #35
Prokits have the least amount of drop. Therefor they are a taller spring, requiring more compression to mount over springs that drop 1.5 to 2".
Old 06-22-2012, 01:06 PM   #36
TOLMACH
Drives: soarer
^ Makes sense, thank you
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 04:29 AM
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 02:18 AM
Swaybar vs. lowering springs eht13 General Yaris / Vitz Discussion 52 10-04-2010 08:59 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 02:23 PM
