Old 06-21-2012, 07:08 AM   #1
Originally Posted by CrankyOldMan View Post
I went with a much more expensive option: buy a second set of spring retaining hardware. While it cost about as much as a decent set of spring compressors, I won't ever have to mess with one: each spring stays mounted on its own shock.
Every aftermarket spring I've put on can be put on the strut without a spring compressor EXCEPT Eibach prokits
Old 06-21-2012, 07:55 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Indeed, but I'm going to be swapping out springs & shocks every fall/spring. This way I won't need a compressor to dis-/re-assemble the OEM springs twice a year.
Old 06-21-2012, 12:01 PM   #3
i did the same for a couple years...then i got sick of doing it twice a year and just run eibach sportlines year-round.
i run taller tires in the winter, though....gives me an extra 1/2" of ground clearance
Old 06-22-2012, 11:04 AM   #4
TOLMACH
Drives: soarer
Interesting.. what was different with pro-kits?
Just ordered myself a set.. hopefully this works for yaris.
http://www.ebay.com/itm/130621365599...84.m1497.l2649
Old 06-22-2012, 11:07 AM   #5
Prokits have the least amount of drop. Therefor they are a taller spring, requiring more compression to mount over springs that drop 1.5 to 2".
Old 02-18-2013, 10:20 PM   #6
Yarflana
Drives: 2008 Base Model
I just installed Tokico reds and Eibach pro kit springs and DID NOT have to use a spring compressor to install; however, of course needed it for the stock spring removal for the parts that would transfer to the Tokicos.
I can safely say I will not need a spring compressor in the future to remove the Eibachs...they are shorter than stock enough to avoid the need for the tool.
Yarflana is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
Micro Image lowering springs 1.8" drop markylicious Middle East 144 10-30-2011 01:18 AM
Swaybar vs. lowering springs eht13 General Yaris / Vitz Discussion 52 10-04-2010 07:59 PM
Is it practical to install stiffer shocks without also installing lowering springs? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-18-2007 01:23 PM
