Old 07-04-2012, 11:01 PM   #1
muffin_top
Drives: 2012 Yaris SE 5MT
Yes.
There are two clips holding the pillar to the body. The center clip is standard round style used all over the car. The upper clip is special in that it is designed to hold the pillar in the event the curtain bag deploys.
Pull the trim from behind the weatherstrip toward the center of the car. When it pops loose you can see the upper clip holding it about 1.5 inches from the body. The clip rotates so that the end holding the trim can pulled through its opening thereby allowing it to be removed. It's best to use a needle nose pliers to rotate the clip as reaching it with your fingers will be difficult.
muffin_top is offline   Reply With Quote
OEM tweeter wiring on UK Yaris Paul Evans In Car Entertainment + Electronics (audio / video / alarm) 4 12-16-2024 03:27 AM
Ultimate yaris part out, aftermarket and OEM yaris rs Items for Sale by private party 25 06-20-2011 12:43 PM
OEM Parts hatchbackkid82 Items for Sale by private party 30 12-17-2009 10:08 AM
FS: OEM STUFF darkmoon87 Items for Sale by private party 2 05-29-2009 05:21 AM
